550i Crank Pulley - Febi/Bilstein OK?
So the OEM BMW harmonic balancer is almost $700.
febi/bilstein is under $200. Okay to go aftermarket here or should I stay OEM for the crank pulley?
car is at 140,000mi. Going to do the belts and pulleys as preventative maintainence.
Engine: 3.0 B58; 3.0 M54
Originally Posted by donpb
With BMWs, it's always best to stick with OEM.
Is Febi/Bilstein the OEM belt tensioner pulley as well?
Which one? There's 2 tensioners which are usually sold as an assembly. My go to for tensioners have always been continental
One of these three
https://www.fcpeuro.com/products/bmw-belt-tensioner-pulley-11287542680
https://www.fcpeuro.com/products/bmw-belt-tensioner-pulley-febi-21629
https://www.fcpeuro.com/products/bmw-automatic-belt-tensioner-assembly-11287549588
I see they have the kit you are referring to.
https://www.fcpeuro.com/products/bmw-accessory-drive-belt-kit-adk0024p
The kit you posted isn't a continental tensioner but it will do if that's the route you want to go.
Continental has a kit (CONTINENTAL ADK0024P) that's on RockAuto
cityazndan
Jun 16, 2014 01:37 PM
