550 / 545 Auto Trans Mechatronic Sealing Sleeve
Old Mar 25, 2012 | 10:51 PM
gwf545's Avatar
My Ride: 2015 535D M Sport
I changed my 545's transmission fluid and oil pan/filter last year, but did not change the sealing sleeve since it seemed impossible to do so without supporting the transmission on a stand and removing the rear support. The sealing sleeve is now leaking and I am still unable to figure out how to access it to replace it. I know some members have done it on 6 cylinder e60s which have a narrower transmission (6HP19), but the V8's have a larger one (6HP26)with very little clearance. One suggestion I received was to loosen the rear support bolts, but I don't see how that will help. Has any 545 / 550 owner done a do-it-yourself Mechatronic sealing sleeve replacement and if so, can you provide some suggestions on how it is done? Thanks!
Old Mar 26, 2012 | 11:21 AM
gwf545's Avatar
Nevermind. I got impatient and got quotes from a dealer for $600+ and an indie for $410. Guess where I am taking it....
Old Mar 26, 2012 | 12:09 PM
pjinca's Avatar
Contact member Healthservices, he may be able to help
Old Aug 2, 2012 | 03:38 PM
Only Bimmers's Avatar
My Ride: 98' 528i Manual07' 550i Sport
Hey i just completed mine and did a best practices writeup. You may take a look if you haven't gotten it done yet. And i have a 550i.
https://5series.net/forums/topic/125...lacement-tips/
Old Aug 2, 2012 | 09:18 PM
sachal007's Avatar
My Ride: BMW E-60 530I
cant thank Only Bimmers enough, I am currently in texas for work but the moment i get back, ill be getting a major maintenance done on my car, including replacing the sleeve for preventative purposes.
Old Aug 2, 2012 | 11:29 PM
You left out one important part! Are you doing the maintenance? If you have any questions i am a good way through a major maintenance and then some.
TopPMP
Aug 10, 2020 04:15 PM
E60GUMSL
Jul 20, 2015 03:45 PM
donmoha
Jul 16, 2015 08:31 AM
w84me
Jul 10, 2015 10:56 AM
Hyper_545i
Jul 1, 2015 05:07 PM
