545i oil pressure sensor changed but low pressure warning remains on
Old 04-20-2024, 01:22 PM
Webweaver's Avatar
My Ride: 2004 E60 545i
Hell the only things I can think about is not torqued all the way (27Nm), debris in pickup, or software issue. Did you clear the code and unplug negative terminal for a few mins to see if it would come back. This is a hard issue because there's not much to replace a sensor. Do you know the code it's throwing
Not sure what you mean by negative terminal. There is only a single wire and connection on the switch. Not got code I’m afraid
Old 04-20-2024, 01:35 PM
seanjordan20's Avatar
My Ride: 05 530i M54
Model Year: 05 530i
Engine: 3.0 M54
The battery. Hold on you have a low pressure light without a code. What did you check with
Old 04-20-2024, 01:41 PM
Webweaver's Avatar
only have Carly. It shows some codes. Will get screen shot
Old 04-20-2024, 02:20 PM
Model Year: 05 530i
Engine: 3.0 M54
Do you have an aftermarket alternator or original. Check your BSD line on your alternator
Old 04-20-2024, 02:23 PM
Webweaver's Avatar
180A 6VEE DIA B+ (MB ) C alternator installed about 6 years . What is BSD line please?
Old 04-20-2024, 02:42 PM
Model Year: 05 530i
Engine: 3.0 M54
The green wire that plugs into the alternator
Old 04-20-2024, 02:46 PM
Webweaver's Avatar
Ok will have a look tomorrow (almost midnight here) and run another diagnostic. Everything was fine, apart from oil leak prior to changing switch. At least it stopped the leak 😆
Old 04-21-2024, 09:27 AM
Webweaver's Avatar
Default Update
Still not solved it. Cleared codes and left negative battery cable off for about 20 minutes. Oil pressure warning still there. Have checked outside temperature sensor and cleaned connection as apparent these can cause other faults if not working properly. Not had time to look at alternator. Battery is healthy and fully charged. Being a pre LCI car it has a dipstick for oil level. Is there also a level sensor near oil filter that might affect this?
Old 04-21-2024, 10:00 AM
Model Year: 05 530i
Engine: 3.0 M54
The level sensor should be on the oil pan
Old 04-21-2024, 10:33 AM
Webweaver's Avatar
So I can access from under the car without taking oil pan off?
Quick Reply: 545i oil pressure sensor changed but low pressure warning remains on
