545i oil leak......
My Ride: 545i
Damn it! I was hoping it wasn't that. Does the power steering pump have to be removed? If so can it just hang in position with the lines still connected? 138000kms (86000 miles). Someone should make aftermarket gaskets that last more than 100,000 miles.
My Ride: 545i sport
Yes, PS pump has to be removed and can hang on lines. Alternator has to be completly removed. Left side engine mount and bracket have to be removed. Access is then still tight. Lots of work for a $0.25 profile gasket. Misc. other small stuff has to be removed (heat sheilds, etc).
My Ride: '04 545i, sport pkg, premium sound, sprint booster,
I have the same problem. Car takes a quart of oil every 1 1/2 to to 2 months. Car is sitting at 85,000 or so.
My Ride: 545i
Mines not quite that bad. Changed the oil January and only needed to add 1 quart since then.
This DIY is a PITA!!! Takes about 6 hours to change a $3 gasket. I did this with a help of a friend (also a member here) over a couple of weekends because we had to figure things out as we went. Basically, the radiator cover, fan, alternator have to be removed and out of the way. Then, the fun really starts, once you remove the power steering pump and hang it out of the way, you need to undo you motor mount on the driver side and raise the engine a bit. The bracket sits behind the motor mount using the motor mount bolts to hold everything in along with a handful of bolts for the bracket itself.
Look up the DIY that Heathservices did here (I think it's titled Leaks Leaks! ...). He's also a friend of mine who helped me get through everything and also recommended that I change the valve cover gaskets and upper timing chain covers while I was at it. Be warned, you need to have a good selection of tools before you start on this. Also, it's makes a world of difference if you have access to a lift. You will have saved yourself $1600-1800 afterwards. Good luck.
My Ride: 545i
My Ride: 2004 545i 6 speed, Silver Gray A08, Gray leather
Mods: Hard-Wired Passport 9500ix LIVE , K&N Air + RPi Scoop, Mtech V2.1 AE, ACS pedals+Ebrake, flip up front plate, OEM 172's, Custom M Kit, M3 shift knob, Eisemann Race Exhaust
2005 X5 3.0 (the nightmare)
1998 528i SOLD @ 173K
Do it ASAP! mine started leaking and a few days later it was dumping oil out of the bottom on the thruway. Smoke coming from the vents etc it was almost fatal
