545i /e60 vlave guides
Old Jan 22, 2012 | 01:58 PM
jlshand's Avatar
I have been told by an Indy that the 545i's have a high frequency of valve guide problems at 100,000 miles + The fix requires a good 30 hour of labor including what amounts to a rebuilding of the engine. I love the car and would like to know if this problem is factual and frequent.
Please add your thoughts/opinions and/or experiences. IE Have you heard this is a common problem.
Thanks
Old Jan 22, 2012 | 08:08 PM
turboawd's Avatar
My Ride: 2006 BMW 550i
never heard of this. what did he say exactly happens to the valve guides?
Old Jan 23, 2012 | 06:54 AM
jlshand's Avatar
Brittle and break. Bad material to begin with. symptoms are HEAVY oil Burn and exhaust smoke.
Old Jan 23, 2012 | 07:08 AM
jaycal3's Avatar
My Ride: 04' 545i, Sport Package, Black, Active Xenon, ARS, Aux Input '10 Tahoe, Black on Black, leather, Nav/XM, 20" tires, full body kit, power 2nd row, loaded '93 Jeep Wrangler, lifted 4.5", 33" meats, Rampage Recovery Bumper w/Tire Swing, etc 25' Aquasport Osprey, Center Console,2012 200 HO Etec
New to me ... You may want to seek another opinion since you seem to be questioning the legitimacy of the claim. You NEED a mechanic you trust. If you cant find a good indy shop, spend the money to have BMW tell you whats wrong before you sink that much cash into it.
Old Jan 23, 2012 | 07:50 AM
pukka's Avatar
My Ride: 2008 535i: (8/07 Build) Metallic Bronze, Beige NASCA Leather, Ventilated Seats, Sport Pkg, Cold Wxr Pkg, Logic-7 Sound, HUD, Night Vision, PDC, Split Rear Seats, NAV, Premium Pkg, Comfort Access, HD Radio, Sport Auto Trans Current mods: M-Aero Kit, JB4, Motorcepts 6000k HID Foglamps Umnitza ICE-Lite 10w LED 6000k AE's 1992 Camaro RS: Fully Restored w/Custom Interior, 5.0L V8, T-tops, OEM Z28 Foglamps, Inst Cluster, & Spoiler, Custom Sound, Too many engine mods to list
Your car has two valves per each cylinder (2x8=16 valves) the valve guide/seal needs to be replaced on EACH one of them. The engine may need to be removed depending on how much clearance there is to get to all of the valves. This is not an engine rebuild as long as the cylinder heads don't need to come off.
30 hours of labor still seems excessive so I would definitely get another opinion. Good luck.
Old Jan 23, 2012 | 12:41 PM
healthservices's Avatar
valve guides hold and guide the valve.
Valve guide seal prevents oil from engine from sucking in oil down the guide.
Old Jan 23, 2012 | 12:47 PM
turboawd's Avatar
he is either full of it, or talking about something else. the valve guides are metal and pressed in the heads. they dont get brittle and break. usually they wear out with very high mileage, and you'd see smoke out your exhaust.
now if it were the valve stem seals going bad, you'd see smoke coming out of your exhaust too.
Old Jan 23, 2012 | 01:36 PM
jlshand's Avatar
Thanks everyone. Turbo, I understand that either bad seals or bad guides can cause smoke and or excessively oil use. Which of the two problems requires a 25 30 hour repairand is either one tending to happen a lot in particular, with the n62 engines at 100,0000 mile's. Plus????
Old Jan 23, 2012 | 04:00 PM
vini545i's Avatar
2004 545i 106k here are def starting to see this problem occuring. Im in the process of tryin to find some extended warranty that covers it or something, or sell it ... i love my car but really disapointed at how bad they are, ive had bad oil leaks and other problems like windows modules going retarded, rattle noise from engine and ive always babied the car.. always fresh oil coolants always topped and problems just seem to keep coming...
Old Jan 23, 2012 | 08:13 PM
turboawd's Avatar
if you have bad valve stem seals, you'll really notice smoke when idling, and especially after idling for a while and then giving the engine gas....thats when the smoke shows the worst.
