545 manual pops out of 1st gear
Old 06-13-2006, 07:50 AM
needforspeed's Avatar
Originally Posted by Ray Hull' post='296948' date='Jun 13 2006, 04:48 PM
If you are certain that you are fully engaging the shift lever into first gear, and it is popping out, you should take it back to the dealer immediately. Have the service rep RIDE with you to see it happen. I can only assume that your seat is adjusted properly and that you are depressing your clutch pedal fully and shifting positively.
This is NOT normal and could be very costly if the gears have been damaged. Maybe it's just linkage adjustment, but it sounds more troublesome than a random missed lever placement.
Good luck,
Ray Hull
Yep jumping out of gear isn't good. It IS possible not to engage a gear fully, but BMW gearboxes are very 'positive' and not prone to this.
If your can is jumping out of gear then I think you have a gearbox fault.
Old 06-13-2006, 04:30 PM
hinckley's Avatar
I have never experienced this problem on a BMW. However, I once had the exact problem on a brand new Acura Legend some years ago - it required a new transmission (replaced when the car was one week old). I'd push hard to determine the real cause before your car goes out of warranty.
TopPMP
08-10-2020 04:15 PM
DJ JoeyG
11-09-2015 07:24 AM
teerapote
07-29-2015 11:50 AM
Bank$hot530
07-12-2015 04:36 PM
tafmat03
E39 Discussion
07-01-2015 08:50 AM
Quick Reply: 545 manual pops out of 1st gear
