545 Hesitation from the stop
Old Dec 2, 2004 | 06:20 PM
  #21
Iceman's Avatar
My Ride: F02 LCI Individual
Model Year: 2013
Welcome aboard, ipp !
Old Dec 2, 2004 | 08:28 PM
  #22
dba1t's Avatar
For the record . . . when the vehicle is stopped and idling the automatic transmission is in second gear. The hesitation you experience when pressing the accelerator is the transmission downshifting to first gear before pulling away. Whether in D or DS mode, the transmission will operate in this manner. Downshifting to M1 while in DS mode will eliminate the hesitation, although manual intervention at every stop is unsatisfactory for most of us.
All versions of the E39 automatic transmission (Steptronic, non-Steptronic, 4-speed, and 5-speed) did this as well. The difference is that the E39's downshift operation from idle was much quicker and nearly imperceivable. The E60's downshift operation from idle is slow and noticable. Adjusting the idle may help to mask the hesitation, but the problem remains. The issue exists within the ZF 6-speed or the transmission programming. Perhaps someday we will know the exact cause.
Old Dec 2, 2004 | 08:47 PM
  #23
sg530's Avatar
So, dba1t, spirited acceleration from a standstill invokes a downshift to 1 while a regular take-off starts in 2nd with shifter in D? We do not get 6 gears while in D ever?
And, in addition, the other comment, that in DS you get no 6th? Is the gear not accessed yet just displaying 6th? I thought I saw 6.
Now can anybody answer my outstanding question from months ago; is there a torque converter lock-up in this transmission? I can't feel it engage. <_<
Old Dec 3, 2004 | 03:31 AM
  #24
ULtraPLanet's Avatar
Originally Posted by sg530' date='Dec 3 2004, 07:47 AM
And, in addition, the other comment, that in DS you get no 6th? Is the gear not accessed yet just displaying 6th? I thought I saw 6.?
[snapback]63841[/snapback]
DS mode is different than manual mode. You get DS mode by moving the shifter to the left ONLY. Once you move the shifter forward or backward from the left position (DS mode) you enter manual mode. In manual mode M6 is available but in DS mode the car will never shift into 6th gear. To see what I am talking about the next time you are driving on the highway knock the shifter to the left without pushing it forward or back and you will feel the car downshift to 5th.
Old Dec 3, 2004 | 07:43 AM
  #25
Guest
Guest
Posts: n/a
[snapback]63801[/snapback]
thanks!
Old Dec 3, 2004 | 09:12 AM
  #26
gomac's Avatar
Originally Posted by ULtraPLanet' date='Dec 3 2004, 01:31 PM
[quote name='sg530' date='Dec 3 2004, 07:47 AM']And, in addition, the other comment, that in DS you get no 6th? Is the gear not accessed yet just displaying 6th? I thought I saw 6.?
[snapback]63914[/snapback]
[/quote]
I used M mode today for the first time (finally out of the break-in mode after the meet) I shifted back and forth a couple of times. I left it in M3 forgetting about it for a moment when my wife called on the cellphone. The traffic light changed, I started up looked down at the instruments and noticed it was still in M3. Did it start in 3rd?
Old Dec 3, 2004 | 09:23 AM
  #27
kscarrol's Avatar
My Ride: E90 M3
Model Year: 2011
Originally Posted by gomac' date='Dec 3 2004, 12:12 PM
[quote name='ULtraPLanet' date='Dec 3 2004, 01:31 PM'][quote name='sg530' date='Dec 3 2004, 07:47 AM']And, in addition, the other comment, that in DS you get no 6th? Is the gear not accessed yet just displaying 6th? I thought I saw 6.?
[/quote]
[snapback]64025[/snapback]
[/quote]
It probably did. I've never done that one. I think the computer will step in and stop you from doing something that will harm the engine, like downshifting from 5th to 1st, starting in 3rd, while a bit sluggish maybe, is probably not very harmful to the engine or transmission.
Old Dec 3, 2004 | 12:10 PM
  #28
Tim C's Avatar
My Ride: 2004 545iA Titanium Silver/Gray, Poplar----Cold Weather Pkg, Comfort Seats, Logic 7 Audio, Heated Rear Seats
Yes. Can be handy under slippery conditions.
Old Dec 3, 2004 | 12:14 PM
  #29
Guest
Guest
Posts: n/a
[/quote]
[/quote]
I do mostly city driving and whiile in M if I shift to 4th, it will automaticly shift back to 3rd if my speed is not great enough to keep the revs above 1K.
In a 545 I have started from 3rd and the car takes off a little more smoothly, although more slowly till it hits the strong part of the tourq curve. I don't know if a 530 would have enough torque to pull this off.
I think the delay is caused by the lack of pressure in the torque converter. It takes an instant to build pressure before acceleation is felt. This is why @ 750 the hesitation is not a notible because the higher RPM is creating more pressure. Too much pressure at idel and the car would tug when at a stop, but there would be no delay.
Old Dec 3, 2004 | 12:16 PM
  #30
noonehome's Avatar
oops above was me...
