535D Lost Power in low end revs
Old 08-02-2011, 07:46 AM
AI001's Avatar
Cleaning up EGR can also help. Check EGR hoses and pressure converter too.
Old 08-02-2011, 02:11 PM
Anzafin's Avatar
My Ride: Bmw 530d 2004
Also check is there any error codes relating to a Diesel Particulate Filter. If the DPF gets clogged, one symptom is the one that you're having.
Read more here:
https://5series.net/forums/topic/947...1#entry1120691
- Antti -
Old 08-02-2011, 11:53 PM
Adam1v's Avatar
My Ride: 535D
Is this easy to get to? Is it visible from my photos above? Im more of a computer geek then mechanic
When I get home, I will check the arm on the waste gate valve, but unless its loose, I wont really know what i'll be looking at.
Old 08-03-2011, 01:08 AM
AI001's Avatar
No, its not easy to visually inspect these elements. You need to open EGR valve to see how dirty it is. Its not that difficult job but still requires some mechanical know-how. Even I am more into computers but given the prohibitive and often unreliable cost of repair from dealership (and even local indy) I did that all myself.
Old 08-03-2011, 03:25 AM
Adam1v's Avatar
My Ride: 535D
AI,
is the EGR visible in this image:
or can you link to a better image?
If I can take a look at it, I might decided whether or not to take it on.
Old 08-03-2011, 06:37 AM
Anzafin's Avatar
Here's my thread about cleaning the intake manifold. It includes the cleaning of the EGR valve. It's for 530d but it's the same with a 535d.
Please note that I removed the whole intake manifold, but you may be able to remove the EGR valve without removing the intake manifold.
- Antti -
Old 08-03-2011, 08:10 AM
AI001's Avatar
No, egr is not in the picture you gave above. Its on the other side of engine. One where the black charge pipe connects to the intake (spring side)
Old 08-03-2011, 10:48 PM
Adam1v's Avatar
My Ride: 535D
I took a look at this last night, managed to get everything off except the two bolts underneath the EGR which were extremly difficult to get to.
I might just bite the bullet and take to a dealer
Old 08-04-2011, 01:23 AM
AI001's Avatar
Take your time no hurry, its easier done if you take the fan cowl out.
IMO, I won't go to the dealer. Go to local independent dealership which specializes in BMW particularly bi-turbo engines like 335d and 535d. You and your wallet will regret going to main dealership. They know nothing and first this they will do is to replace everything at your expense, I think first they will replace your turbo(s) to start with. You will be cornered then and if you decide not to go ahead still you will end-up paying their diagnosis charges which can easily be in £200+.
This is my experience, you have warned, take you own decision.
Old 08-09-2011, 10:22 PM
Adam1v's Avatar
My Ride: 535D
AI,
I dont really have a choice im afraid
Its now booked in for today and will be collected.
I know my local dealer doesnt have their own mechanical department themselves, it is outsourced to another local garage, so hopefully it wont be too steep.
Once its sorted, i'll post the issues / costs here later today (hopefully).
I REALLY cant wait to get my fast car back
Quick Reply: 535D Lost Power in low end revs
