535d Intermittent Accelleration Problem
Old Oct 9, 2009 | 02:48 AM
Mambo's Avatar
My Ride: 535d Sport Carbon Black, Black Dakota leather, Media Package, Bluetooth, Bi-xenon headlamps, adaptive headlamps, auto dimming interior mirror, heated folding door mirrors, electric front seats with drivers memory, heated front seats, extended light package, sun protection glass, electrically adjustable steering column, automatic air conditioning.
Thumbs up
Wonder if anyone can help, I have a 2005 535d which has been remapped by DMS and is exhibiting some very strange behaviour...
After the car has had a hard run (kick down up to about 80mph) the next time you kick down, the revs rise to 4000 rpm but the car refuses to accelerate, it just holds it?s revs.
After quite a bit of investigation by my local independent and a replacement changeover valve I had the car ECU flashed back to normal and the problem went away.
DMS came out a couple of weeks ago to reapply the remap and the problem is back ? I?m not sure what?s going on as I?ve had the remap since 2005 with no problems.
Any ideas?
Old Oct 21, 2009 | 08:13 AM
Mambo's Avatar
No ideas?
DMS came up yesterday and checked the map and said it was OK - they thought it "could be" the MAF. Don't really want to change it if it's not gonna fix the problem....
Any ideas?
Old Oct 21, 2009 | 09:02 AM
stiker's Avatar
My Ride: 535d M Sport / Carbon Black Metallic / Aluminium cube / black leather sports seats / Prof. SatNav / Bluetooth.
Have you seen this? Clean the MAF rather than change it....
Hope you find an answer soon.
How much meaner does the 535d feel with DMS than without - now you have swapped back a forth?
GL
Old Oct 21, 2009 | 10:32 AM
or_550i's Avatar
Originally Posted by Mambo' post='1037428' date='Oct 21 2009, 09:13 AM
No ideas?
It's not the MAF. The MAF at high speed would not lock revs. If you had a rough idle or emission problems it would be MAF.
I had problems with the steptronic transmission where when the car was running at a constant speed [usually slow speeds <35mph] the transmission/ECU would try to conserve fuel by enabling the lockup torque converter. The work around, as told to me by the master mechanic at the dealership, is to use the 'sport' mode.
I would guess the issue you have is ECU/Transmission related.
Old Oct 21, 2009 | 11:41 PM
Mambo's Avatar
GL
Thanks - I'll give that a shot.
The DMS map makes a hell of a difference, really transforms the car. I can feel it a lot more now that I have had it taken off and put back on - I think I must have gotten used to the power!
Old Oct 22, 2009 | 12:20 AM
Mambo's Avatar
Hmm - I'll get them checked out when I next take my car in to the garage...
Thanks!
Old Oct 22, 2009 | 06:27 AM
stiker's Avatar
Forget to add the search link for cleaning the MAF ...good DIY write-up...
https://5series.net/forums/index.php?showtopic=73614
Old Nov 4, 2009 | 12:26 AM
MNC2008's Avatar
Any ideas?
I had a prblem on very high speeds, where I felt that the 2nd turbo had switched off. This problem went away after re-starting the car. The dealer replaced the turbo pressure regulator. There are 3 regulators which control the 2 turbos. After this repair - ?500. The car seem to have the problem you addressed above and the dealer then replaced all the vaccum pipes around the engine and now the car is back to normal. Hence check for worn vaccum pipes in the first instance!
Old Jan 20, 2010 | 06:47 AM
Mambo's Avatar
Just had the hoses replaced and it seems to have fixed the issue
Grrrit
Jun 10, 2015 01:04 PM
Sandrokarton
May 20, 2015 05:53 AM
Steve J
Apr 17, 2015 08:10 PM
Quojo
Apr 1, 2015 04:00 PM
dv8ed
Dec 24, 2003 07:41 PM
