the 530i 3.0 engine and 98 octane!
#21
There was an old discussion about octane EU vs US.
Found by Search.
No matter if the gas engine is a N or M,
the higher octane gives better power.
The reg gas in US is lower octane than in the EU.
All BMW US enigines are given less hp values do to this fact.
Just use the 98 octane, you'll get more out of your E60 engine.
Found by Search.
#22
Found by Search.
All US enigines are by BMW given values less hp do to this fact.
The gas in US is lower octane than in the EU.
Found by Search.
1 PS = 0.98632 hp (SAE)
Also the US measure for fuel octane is about 4-5 points lower than the equivalent measure used in most areas of the EU. Therefore, the common premium fuel in the US is 91 Octane (AKI or (R+M)/2) and the comparable EU equivalent would be about 95-96 Octane (RON). There are a few stations (Shell) here that also offer 93 Octane (AKI) fuel that would be about the same as the EU's 98 Octane (RON).
This should really be made into a sticky since it comes up all the time.
#23
Hi fellows!
I found this video called "Which fuel produce more HP" made by Fifth Gear.
It is a simple video with some empirical evidence on this matter.
Here:
http://www.autoclips.net/detail.php?id_video=3264
Best regards
Fkuti
Here:
Best regards
Fkuti
