530D wont charge after replacing alternator
Old Feb 7, 2024 | 08:48 AM
Joakim530's Avatar
My Ride: 530d m57tu2. Stage 2 with downpipe, hardcut, xhp stage 3, msport
Originally Posted by habbyguy
The problem is pretty much obvious...
What happened with the original alternator was that the "brushes" (the spring-loaded blocks that make contact with the alternator's rotor) were worn down, making poor or intermittent connections.
Then you ordered a new alternator. All good, right? Nope. The connections were different, so you swapped the old regulator onto the new alternator.
Unfortunately, the brushes are part of the regulator, so you put the only bad part from the old alternator into the new one. It worked for a very short period because of the shiny new contacts on the rotor, then gave up (it'll probably work intermittently if you continued to try to use it).
So... I'd suggest your best course of action would be to order the correct voltage regulator for your car (which presumably will fit the new alternator, since the old regulator did, even if it didn't work for long). Then, with new brushes, your alternator should work again, for a long, long time (assuming you get a quality regulator, that is).
forgot to tell that the regulator on from the old one is changed fall 2023. Brushes are fine, checked it before i put it on the «new» alternator. So its not the regulator.
and for the other guy, yes its confusing. Im confused by this myself. All i know is regulator is fine, and dont understand how it killed the new alternator so fast.
Old Feb 7, 2024 | 01:10 PM
habbyguy's Avatar
My Ride: 2006 530xi (Touring)
I dunno... the fact that the old (Fall 2023) regulator was different somehow is what has me thinking that could easily be the difference.
Also, are both the new alternator and "old" regulator OEM, or no-name parts?
irlgabriel
Oct 30, 2023 01:32 AM
Ovidiu
Mar 26, 2017 06:10 PM
mjojom
Sep 13, 2013 11:55 AM
patelE60
Nov 29, 2012 11:12 AM
JerzyBoy973
Jul 23, 2012 05:49 AM
