525xi staggered tires??ok???
Old Jul 1, 2009 | 04:32 PM
hawaiiane60's Avatar
My Ride: 2006 525xi
Hey guys I wanted to know if anyone else is running wider tires on the back? Everything I've read so far says not to on an xi. BUT I planned on taking my friends tires. She has a '07 or '08 328xi. The tires came off in 2 months of owning it. The were staggered from the dealership. So I was thinking if her AWD came with staggered why couldn't I use the same exact tires.
Any input would help.
Thanks
Old Jul 1, 2009 | 04:33 PM
subarashi's Avatar
My Ride: 2005 545i E60 Orient Blau Metallic Premium, NAV, Winter Package, Heads Up Display, Logic 7 Audio, AngeliBright Upgrade [White], M5 Body Kit, M Embroidered Seats
Thanks
Its a no no on an Xi - that's why they dont require tyre rotations.... Her AWD shouldn't have had staggered tyres.....
Old Jul 1, 2009 | 04:37 PM
My Ride: 2006 525xi
Then how does that explain her 328xi riding on a staggered setup straight from the dealership? 255 on the rear and 225 on the front??
Old Jul 1, 2009 | 04:42 PM
ENstig8or's Avatar
My Ride: 650 Grand Coupe
Model Year: 2016
I'm running mine staggered on my 535XI. You can order the car from the factory with a staggered set. It's fine.
Old Jul 1, 2009 | 04:55 PM
v_therussian's Avatar
What you're refering to is the differential problems (I think it was the differential) that some members reported after running staggered without matching front and back overall diameters. So two things:
1. YOU ARE MISTAKEN. IT IS POSSIBLE TO SUCCESSFULLY RUN STAGGERED ON Xi (Ask DrLev99 and C'sBimmer!)
2. Problems will start if you have different overall tire diameters front and back and wheels will be turning at different rates, thus messing up the sensors for torque distribution front to back and eventually throwing all kinds of errors related to differential...
Old Jul 1, 2009 | 05:50 PM
My Ride: 2006 525xi
Originally Posted by v_therussian' post='929969' date='Jul 1 2009, 04:55 PM
You can run staggered on Xi, just have to calculate your overall wheel diameters and make sure that front and back overall diameters are not more than a "few" millimeters difference. I.e. if your fronts are 653mm (for example), your back should not be more than 670mm TOPS!!! You have to try to match the tires as much as possible so that the overall diameters of the front and back wheels are as close to each other as humanly possible. Google "wheel size calculator".
That is more informative......I think when people search for the same issue I think they'll find the answer here.
So basically, If I go with 18" up front I need to stay with 18" in back, unless you modified the sidewall tire ratio ie: 40 or 45 series to be almost exact in overall tire/wheel diameter. So my setup with 225/40/18 front, 255/35/18 back will work fine.
Thanks for you help!!!!!!!!
ebrown71
Jul 7, 2023 03:00 PM
Derm
Jan 26, 2017 07:38 AM
alexp1
Jun 17, 2015 11:38 PM
vapostol
Jun 4, 2015 05:09 PM
Gizmo
Lounge
Jul 16, 2004 05:15 PM
