525i e60 front end uneven: help please!
Hi there
1) noticed that my passenger side is lower, the clearance between the wheel well and tire is smaller on that side. Also when I jack up the car, the tire on that side is dripping lower,
2) I thought it is the struts, so I changed all the struts and springs. But nothing changed. The passenger side is still lower and when I jack up the front end, that side is still lower.
What is the problem?
Thanks in advance!
HB
Thanks in advance!
HB
Thanks for prompt response. This car has a sports package. Stii macphrson struts, but lowering a little bit. No alignment done yet, but will alignment affects this?
Thanks again
HB
Thanks again
HB
If you changed the struts you need an alignment. I would take it to a good place and let them have a look.
Thanks again for responding.
1) Wheel gap left: about 1 inch; right: about 0.5 inch
As I said , if I jack up the car by the center front jack point, the right wheel/tire is lower than the left too.
2) alignment seems ok since it can drive straight for a long distance with steering wheel centered straight
Thanks again
HB
Thanks again
HB
My Ride: 2006 BMW 550i
wasnt it said that the driver's side sits a bit higher to compensate for driver's weight?
only thing i can think of besides a bent chassis, is maybe the anti sway bar is bent or twisted.
The car has never been in accident. I also suspect the sway bar. First I do not know why; secondly I want to confirm by some experts here.
Thanks again
HB
Thanks again
HB
