525d LCI torque curve / 530d LCI torque curve
Old 10-23-2007, 11:48 PM
525d MSport's Avatar
I understand that the one of the differences between the 2993cc diesel engines is the turbo size.
This is certainly suggested by the power curves i.e. once spinning the larger turbo is showing its advantage.
With what I know of turbo charging the smaller turbo of the 525d makes itself known earlier by spinning up very quickly and hence maximum torque at 1300rpm.
Comparing to other engines out there however 400Nm is pretty conservative for a 3 litre diesel and the way the torque curve is clipped, suggests to me at least that there is plenty more to come. E.g. MB E220cdi 400Nm, E280cdi 440Nm, E320cdi, 540Nm
Certainly from the threads on remaps there is suggestion of another 100Nm which if you extrapolate the curve does seem possible. It would be a much narrower rev range though.
Any one else got any further technical knowledge that they can lend?
Any one know why BMW might limit the torque to 400Nm? Is it just to create some "space" between engine specs, or is something to do with car taxation in some countries?
Regards
525d LCI torque curve / 530d LCI torque curve-torque_curve.jpg 525d LCI
525d LCI torque curve / 530d LCI torque curve-torque_curve1.jpg 530d LCI
Old 10-23-2007, 11:52 PM
ipp
ipp's Avatar
My Ride: 07' 530d - M-Sport - Titanium Silver / Black Dakota leather 08' 120i - M-Sport - Alpine White III / Black Sensatec
I think it has to do with the 530d.
btw, I'm quite dissapionted with BMW using the same engine for a lot off 'different' engines. Too much Volvo for me... :thumbsdown:
Old 10-23-2007, 11:55 PM
ipp
ipp's Avatar
From the torque curves you can also see that the 530d has a much wider torque aspect. ex. 400+Nm from 1300rpm to 4100.
christoepurrr
12-15-2015 10:25 AM
spykes
08-11-2015 05:38 AM
ROCKITMAN
07-13-2015 02:16 AM
Tonemapper
07-05-2015 01:08 PM
kammy6000
07-02-2015 05:05 AM
Quick Reply: 525d LCI torque curve / 530d LCI torque curve
