523i 2009 starting/screen issue
Old May 13, 2017 | 03:55 AM
Abdullah Hossen's Avatar
My Ride: 523i 2009
Default 523i 2009 starting/screen issue
Hello fellow bmw lovers.
a couple of days ago my bmw started feeling a bit weird when starting it.
like everything flashes when it starts and the car feels a bit weak when i start it.
and last night after driving it and turning it off by around 5 min i tried to turn it on and no power car is dead .
i left it to be after around 5 attempts , and after that by around 1 hour it worked on the 2nd try and now works everytime but the screen is jammed on the main menu.
what suggestions do you have?
no warning signals or anything were given at anytime.
Old May 13, 2017 | 10:23 AM
seanjordan20's Avatar
Engine: 3.0 B58; 3.0 M54
Have you checked the battery. If it's old replace it
Old May 13, 2017 | 01:31 PM
NoQuarter's Avatar
Engine: N54
Charge your battery
Then have the battery tested/replaced
