5Series.net - Forums
-   -   4x4 AWD, DSC and ABS malfunction (https://5series.net/forums/e60-discussion-2/4x4-awd-dsc-abs-malfunction-152349/)
Milleritme282 Mar 21, 2022 05:57 PM
2010 bmw 535i xdrive with 130,000. I try to be a DIYer and had to replace the right side front axle and gear oil about 3 weeks ago. Everything was good for 3 weeks and now I'm getting a 4x4 AWD, DSC and and ABS malfunction warning along with codes 5DEC Clutch Gear Box and 5E4D Wheel Speed Sensor Front Right. I have cleaned both front ABS sensors with no luck.
When I back out of my driveway (2 car lengths) the ABS feels and sounds like its engaging when I apply the brakes. Then I put it in drive and get 4X4 AWD, DSC, and ABS malfunction almost instantly. After I get the malfunction message the car runs fine. I am going to change the front right ABS sensor. Has anyone else had similar issues and what was your fix?
twh Mar 22, 2022 08:55 AM
When you replaced the right side half shaft, what part did you use and where did you get it?
Milleritme282 Mar 22, 2022 10:30 AM
I bought an axel from Napa Auto Parts. I believe it is their brand.
Constant Velocity (CV) Driveshaft - Front Right - NewPart #: NCV 941125
Line: NAPA Premium CV Shafts
twh Mar 23, 2022 10:34 AM
I will say that I've read a lot of threads where people used non-BMW or non-OEM parts for driveshafts or axle shafts and just had problem after problem. The OE supplier was GKN if I recall correctly. For all the ones I've seen I would not use anything by BMW or GKN.
Milleritme282 Apr 6, 2022 05:16 PM
Update. After replacing the front axle I was getting the 4x4 AWD, DSC and and ABS malfunction warning. I ended up getting ABS sensors from carparts.com and replaced the right side and have not had a single issue with the car since. I know a lot of people say to use BMW OEM replacement parts but so far so good. NAPA CV axle front right $145, carparts.com (2) ABS sensors $60 and my time (priceless).
