30FF only during highway passing; Most likely cause?
Old Jul 31, 2023 | 12:16 PM
spectre6000's Avatar
My Ride: E61
Default 30FF only during highway passing; Most likely cause?
I get a check engine/reduced power warning when I really get on the throttle. Low boost. Searching lists a number of potential sources, but also a number of different presentations. Idle is fine, and I wouldn't know anything was wrong during normal driving. I've gotta get on it for it to happen. I'm planning to replace the vacuum lines because they're cheap and it's time ('08 w/ 95K miles), but I'm not familiar enough with the systems' function to know if that's actually a likely fix. Is there anyone more familiar with the induction systems' workings that can point me in the right/most likely direction given the presentation?
Old Jul 31, 2023 | 02:03 PM
kd7iwp's Avatar
My Ride: 2009 535xi Touring 6MT, 2019 i3s
Engine: N54
Do you have any wastegate rattle? I found that when my wastegates were shot I would get a 30FF when I gave more than 1/2 throttle around 2,400 RPM. Sounds like that could be your highway speed?
Old Jul 31, 2023 | 02:05 PM
My Ride: E61
No rattle that I've noticed, and I'm the sort that notices that sort of thing for sure. Mine is RPM dependent; speed doesn't matter (though I've never done it in neutral or anything like that).
Munich77
Jan 11, 2010 02:02 PM
pininfarina
Aug 25, 2009 01:12 PM
1stbimmer
Oct 8, 2007 08:07 AM
drjochen
Jan 18, 2006 11:36 AM
JayEll
Apr 2, 2005 02:07 PM
