285/35/19 fit ?
My Ride: 2006 550i sport package, manual, black on black w/ anthracite trim, pdc, logic 7, cold weather pkg.
Originally Posted by Superbeat1' post='882204' date='May 18 2009, 03:34 PM
ordered new wheels and want to put 285 35 tires on because the 20s were to harsh. the tire shop is telling me that it wont fit and i should use 275 30
the wheels are 19x9.5 et 25
That is the exact setup i just ordered for my 19's.
Try searching at the top right Google Toolbar.
This exact topic has been talked about in length on this forum.
With ET25 in the rear on 9.5" rim, you can run 285/30/19 if you want to. The 285/35 isn't as ideal but it would work. The problem is that your front rim has to be 245/35/19...which would put you way "off spec" on a 285/35 rear.
My Ride: 2004 545i - 6 speed manual (July 04 build), silver-grey/black, sports package std equipment (18", active roll, active steering, adaptive headlights), premium sound, bluetooth enabled, folding rear seat, lumbar, 3m hood/bumper protective film, rear tint, euro reflectors.
The problem is the front. You have to run a 245/40/19 (not 35) to match the circumference. On a 166m rim with a 12mm offset that is a problem. You need a higher offset to move the rim inward.
The safer bet is to run a 285/30 or 275/30 in the rear. Both will work, allowing you run a 245/35 in the front.
I just like the look of the bigger tires, but they are a bit more challenging.
with 19s in those sizes, recommended size is 275/30/19. with an offset of ET25, you will be fine. you can even run a spacer if you would like as the offset for that size wheel with the recommended tire size and having them flushed is about ET16, but Id suggest putting the wheels on first and seeing how you like the stance it will give your car.
Bank$hot530
Jul 12, 2015 04:36 PM
BurtonSnol3order
Jul 3, 2015 09:28 PM
