20mm spacers on E60
I am thinking of getting a set of Breyton GTS in 20 inch but the website says it is an agressive fit and I need 20mm spacers on the car. The offsets are 35mm on both 20 x 9 (f) and 20 x 10.5 (r) will it be okay with spacers this thick seeing as how most will run 12mm as the biggest. Thanks
You will definetely need the 15 mm spacers in order to get the same look you have with the OEM wheels (offset 20).... if you want a more agressive look, then you will need a bigger spacer...
