I am thinking of getting a set of Breyton GTS in 20 inch but the website says it is an agressive fit and I need 20mm spacers on the car. The offsets are 35mm on both 20 x 9 (f) and 20 x 10.5 (r) will it be okay with spacers this thick seeing as how most will run 12mm as the biggest. Thanks
I would do at least a 15mm
Originally Posted by E60_550i
(Post 1442340)
Thanks |
You will definetely need the 15 mm spacers in order to get the same look you have with the OEM wheels (offset 20).... if you want a more agressive look, then you will need a bigger spacer...
