2010 BMW 535i Ac Compressor
Old Mar 30, 2021 | 01:47 PM
Jvazquez0713's Avatar
My Ride: 2010 BMW 535i
Default 2010 BMW 535i Ac Compressor
My new ac compressor only turns on when jumped. Blows extremely hot when it’s hot out. When it’s cold out it blows warm but not enough to warm up the car. Could this be a fault in IHKA control?
Old Mar 30, 2021 | 04:38 PM
seanjordan20's Avatar
Engine: 3.0 B58; 3.0 M54
What was the reason you changed the compressor? How long ago was it changed. What are your pressures. May not have enough freon? When your heat is on and blowing warm usually it's a bad thermostat or aux pump. Your compressor has nothing to do with heat.
You can check for codes to see if your aux pump is bad using a BMW code reader
Old Mar 30, 2021 | 06:12 PM
The reason I had the ac compressor changed was because it stopped coming on. Also the car would just blow hot air. Took the car to pep boys and they installed a new compressor and said it would only turn when jumped to take it to the dealer. The error codes I am getting are: E706, 9C5C, 9C5D, 9C61, 9C6D and 9C6E.
Old Mar 31, 2021 | 12:53 AM
Pepboys?!? I know Miami has a plethora of Indy shops to choose from.
The first thing I would of done was tell them to put my old compressor back in and get my money back. What did you actually pay for. Your best bet is to take it to an Indy and have them work out your issue unless you have the knowledge to work on the car.
Old Mar 31, 2021 | 01:01 AM
Was there anything done to the car to cause the issue that was self inflicted? We're you trying to code or program something. Has someone tried to fix the blower motor. Your codes are all over the place.
Old Mar 31, 2021 | 01:14 AM
donpb's Avatar
My Ride: '06 530i N52
So basically you have the same problem. Get a refund, and then have an indy BMW mechanic diagnose it.
y0itzflip
May 11, 2019 06:35 PM
Rez
Oct 17, 2018 03:06 AM
Tamas Debreczeni
May 12, 2017 09:48 PM
scotquin
Jul 18, 2013 09:01 AM
tex_phil
Aug 25, 2010 09:08 AM
