2008 LCI sport auto trans.
#21
My Ride: G30 M550i
Model Year: 2018
Originally Posted by curlytoons' post='458164' date='Aug 13 2007, 11:26 AM
My understanding is that the Dynamic Driving Control shifts occur at even higher speeds than when in normal sport mode (DS), a sort of super sport mode. Power steering assist is also reduced, giving more spontaneous response. So, the six discrete combos seems correct.
C
C
#22
My Ride: 08 535i Monaco Blue, Cream Beige, 20x8.5 and 20x10 Iforged Vertex, Toyo T1R, M aero kit coming soon (From Quad M)
Out of curiosity, is there any way to engage the sport mode in a manual trans car? I have not gotten a chance to see a manual trans car and have not heard whether or not there is a sport button. Does anyone one know if sport package equipped cars have the button? Thanks
#23
My Ride: 2006 530i Sport
Silver Gray - Black Leather - Anthracite Maple
Manual Transmission
Premium Audio
Cold Weather Package
Rear sunshade
Sirius Radio
Autobahnd Roadblock (3M) film kit
I drove a 550i Sport Auto this weekend - I was very impressed. I'd have no reservations driving one - even coming from a manual. I loved it.
#24
My Ride: 1994 Mazda RX-7
2007 BMW 328xi
2008 BMW 550i (Sep 4 Munich delivery)
Originally Posted by Rudy' post='458147' date='Aug 13 2007, 10:46 AM
This is confusing and the manual doesn't really explain things very clearly.
I don't think modes #1 and #2 are the same as modes #3 and #4. When the stick is to the left, the car uses the transmission's sport program. I think this mode is just like selecting sport mode on a regular steptronic. The car uses a different shift program that upshifts at a higher rpm and holds gears longer before downshifting. Here's a clip of this from the manual:
Attachment 36303
The sport button activates "Dynamic Driving Control" which I explained in post #8 above. Here's a the clip from the manual:
Attachment 36304
So basically, for now, I think my listing of the six discrete combinations is correct -- then again, I haven't had enough coffee yet...![Wink](https://5series.net/forums/images/smilies/imported/wink.gif)
Attachment 36303
Attachment 36304
It's going to be fun..... Rudy are you planning on a different winter tire setup for bad weather? ?I'll be looking to get something to put on mine (here in RI) probably in Nov before I even get 3K miles on it... sounds like Tire Rack is the vendor of choice, not sure about rim size / style / tires though.
#25
My Ride: G30 M550i
Model Year: 2018
FYI, there was a sport button (for DDC) on the SMG manuals but as far as the traditional manuals go, there isn't a button.
As far as winter setup, I still have my (Tire Rack) setup from my 2004 E60 which are Dunlop M3 tires mounted on 17" wheels. I'll most likely use them unless, for some reason, they don't fit. The only thing I'll have to do is get 4 more TPM sensors installed in them...
#26
My Ride: 2008 550i ZSP with Style 167 wheels
Lou
#27
My Ride: G30 M550i
Model Year: 2018
I'm sure it will not handle as well but I'm used to that during the winter. This will be the first time I drop 2" instead of just 1" but I imagine it'll feel similar to the way the 2004 car felt the last few winters. I like having the extra "cushion" for winter potholes, etc. so I think I'll be fine...
#28
Lou
#29
I use 19" in summer an 18" in winter (245 all around) and I must say, even here in snowy Austria, i have more grip and "fun" than with my old c-class that had 195 on 15". Put differently, i just have more confidence in this configuration than in my previous. It is true, that pressure is force divided by area, so the slimmer the wheels (225 vs. 245), the more grip you have but i am really questioning whether these extra 2cm make a difference. If yes, then everyone in up north in finnland would be driving with the 175 emergency wheel on all four...
#30
2007 BMW 328xi
Originally Posted by rsyed' post='458472' date='Aug 14 2007, 03:20 AM
I use 19" in summer an 18" in winter (245 all around) and I must say, even here in snowy Austria, i have more grip and "fun" than with my old c-class that had 195 on 15". Put differently, i just have more confidence in this configuration than in my previous. It is true, that pressure is force divided by area, so the slimmer the wheels (225 vs. 245), the more grip you have but i am really questioning whether these extra 2cm make a difference. If yes, then everyone in up north in finnland would be driving with the 175 emergency wheel on all four... ![Smile](https://5series.net/forums/images/smilies/imported/smile.gif)
Having said all that - I don't know which of those 3 elements is most important - but I suspect it's the tread pattern & depth that makes the most difference. ?All else being equal - the narrower tire (but longer fore-aft "patch") will cut through snow & slush better. Going to a smaller diameter rim is usually offset partially by a thicker tire (on that smaller rim) so the overall outer diameter of the tire may not be that much less with a winter setup. ?With the greater distance from road to rim - we get more "shock absorbption" from potholes, not necessarily less surface area of tire touching the ground.
