2008 LCI quad projectors
My Ride: BMW 530i M Sport
My Ride: BMW 525dA 2007 pre-LCI.
These are the normal non-Dynamic Bi-Xenon headlamps. The inner projectors only contain the Bulb for the Angel-eyes. Thats why they are black. So except the ring nothing lights up on the inner bulb.
High and low beam is done by the xenon bulb in the outer 2 projectors.
I have these retrofitted on my pre-LCI.
The Dynamic inner ones don't look like projector types either.
Dynamic :
Normal Bi-Xenon one with the black lens :
So if you make the middle part transparant you have no AE anymore.
Maybe just maybe you could replace the part by the conerning lamp of the dynamic headlight. Havn't seen one open yet so wonder how this is made.
Best you take a look in your lamp then it will be clear for you quickly.
As I said before, the AE lamp H8 lamp is in there. It sits in the middle of the lamp just like a normal lamp. As the middle piece is blank only the sides (which are the angle eyes) light up.
My Ride: BMW E60
Model Year: 2016
It's because of how it's designed. The smaller ring is immediately lit up by the bulb behind it, whereas the larger ring has to travel through two different optics to light up the entire large ring.
milhouse4u
04-22-2015 04:43 PM
