2008 dead CCC
My Ride: 05 530i M54
Model Year: 05 530i
Engine: 3.0 M54
Originally Posted by kd7iwp
I will say that if you put a CCC in that isn't coded for your car you may not get sound if it came from a vehicle with a different sound system. First time I plugged my new CIC in I had no sound as it came from a car with hi-fi and I had to code it for Individual Audio before it would output sound over the MOST optical bus to the amp.
My Ride: 2008 BMW 535xiT automatic
Model Year: 05 530i
Engine: 3.0 M54
Originally Posted by Jgb67
@seanjordan20 I'm interested to know more about your comment. A simple default code?
There is a tool called NCS Expert that can modify settings/parameters inside the modules in our BMWs. In addition, a few modules keep track of the VO (Vehicle Order) which is a set of option codes specifying which features your vehicle has. When you install a module from another car it is most-likely not configured correctly for your vehicle. When this happens, you can tell a module to read your car's VO to reset itself to factory settings for the options your vehicle came with. I'm not going super into detail here, but here is a link to a PDF that gives the rundown. If you haven't used NCS Expert before then it can be a lot to learn and I recommend finding someone who knows how to do it. I spent quite a bit of time researching and figuring this out before I started retrofitting and customizing things on my cars.
https://www.spoolstreet.com/threads/...-modules.3027/
roskinc
03-01-2013 02:20 PM
Almighty JungleBoy
02-28-2008 11:28 PM
