2008 550i Clunking noise
My Ride: 2008 Space Gray 550i
Greetings all! So here we go: Several months ago while parking in my garage space, I put the car in reverse and began backing up into my space, slowly tapping the brake pedal and turning the wheel when I heard a loud clunk/thud. As I heard the noise, I felt it on the brake pedal and steering wheel (simultaneously?). It is now a regular occurence and I have been to the dealer three times, but when I get there, the car does not replicate the noise. SA states that it could be the transmission, but there is nothing that they can do unless they replicate the noise with a tech in the car.
to summarize:
Loud thud/clunk noise
Only happens when in reverse
Feel a slight virbration on the brake pedal and steering wheel
Any thoughts would be helpful.
Thank you!!!
to summarize:
Thank you!!!
Tony
I'd guess one of the front lower ball joint is the cause of that noise.
Only way to verify that is to look at the ball joints while someone turns the steering side-to-side.
