2008 535i e60 n54
I’ve had my 535 for about 2 1/2 years now. About a year in I started getting these slight shakes I get them either when I’m holding a speed over 45 or when I’m at a red light it’ll shake and then go away then come back, I brought it to my local shop and I was told it was a vanos issue I had them replaced. But the code came back then I got the whole camshaft timing unit replaced, still the same shakes. After that kinda gave up on throwing money into finding the problem and I just drove the car with the shaking. Now I’m getting these codes 2AAF fuel pump plausibility and 2A2D fuel low, pressure system, fuel pressure. At this point I don’t know if I should have my low pressure fuel pump changed or high pressure or both?
Administrator
My Ride: 530xi
Engine: N52
Shakes are generally indicative of something going on with the suspension system, your rims or motor mounts. Depending on your mileage and previous replacement, I would look at:
- shocks/springs
- motor mounts
- alignment
- ball joints
- bent/cracked rims
- rim hub bore (if not OEM wheels)
Here’s the thing. It’s not a suspension issue. It happens at idle as well while I’m at a light. And while I’m holding a speed of 45+ it’s like waves of shakes that I can feel in my chair. I’ve had suspension work done and also looked at everything is fine there.
My Ride: 535i 6-speed
Not sure how an intermittent coil would act...but it would probably cause a "shaking" sensation when it wasn't firing...or a completely "failing engine" sensation...not sure which. Or possibly a plug issue?
rtorbert
May 15, 2014 05:45 PM
