2008 528i stuck in park
My Ride: 2008 528i
Hello,
I have a 2008 528i with the zf transmission that i cannot get to shift our of park into drive or reverse. Car was shifting alright until I had to put it into neutral by using the lever under the shifter. I am also now getting the transmission fault warning when the car is started. I have pulled the codes and am getting:
4E20 Electronic pressure control valve 1
507B Parking-gear sensors implausible
E094 No message (display transmission data) from the electronic transmission control, receiver gear selector switch, transmitter electronic transmission
control / sequential manual gear box SMC / twin - clutch gearbox.
Any ideas as to why the transmission will not shift into drive or reverse? Thanks in advance for any advice..
My Ride: 530d msport Lci 2007
Check that the release cable has fully returned to the standard position, even though it has been unlocked at the shifter it’s possible that the mechanism is stuck due to inactivity, there’s a good chance it’s never been used before.
My Ride: 2008 528i
Thanks for your reply. Right now I have the cable disconnected at the trans. One thing I forgot to mention is that the car is on jack stands and I can spin both rear wheels by hand but the driveshaft will not turn. Do you have any idea why the wheels will spin without turning the driveshaft. If the car is in park like the shifter is showing, why am I able to turn the wheels?
Consider checking all fuses related to transmission - both front and rear. I had some strange transmission codes and warnings at one time, and it was a fuse splitter that I had installed into one of the transmission fuses in the trunk - it had popped out - leaving the transmission fuse open. I replaced the fuse splitter, checked all the fuses, and everything worked again. Good luck.
My Ride: 2008 528xi
Hello,
