2007 550i CDC Prewire
Hi guys, I am trying to install an used Denison GW500 unit I bought from a member here. He had it installed in a BMW with the CDC and mine is only pre wired. I can't find the fibre optic wires behind the glove box. I did find a set of fibre optic wires behind a small panel in the glove box next to the flash light mount. Is this the correct set? My searching for info has led me to believe this may be a diagnostic port of some kind.
The small plug where the CDC would be mounted only has a pair of wires going into it, I assume +/-.
Hopefully I can figure this out or else I only have an expensive paperweight!
Thanks
the last 4 digits of my VIN are CP03514 am I misreading the CDC prep part?
Thanks
Germaniks
08-09-2015 10:46 AM
w8199
07-17-2015 04:59 PM
