2007 525i radiator fan issue
see that's strange I had heat tho now I notive it gets a lot warmer since new thermo, and I can definatly hear the fan kick on an off like it used to so im pretty sure everything with the temp of the car is fine now.
My Ride: E60 525i M-Sport
Greetings guys, this is my first post right here. So my 525i 2006 have almost the same overheating issue. What were done is as below:
- New coolant hose O-ring (all), and therefore the leak is fixed.
- Cooling system is flushed.
- New coolant with 50+50 mixture.
- Bleeding was done (3 times), just to make sure there's no air.
Are you reading the ODB codes with a BMW specific code reader? It could be that your water pump is starting to die. I would expect some codes, but maybe not with a generic code reader.
thanosE60 (03-04-2022)
Hi, I use thinkdiag mini and it has BMW software inside which reads specific codes for BMWs, as tested before it can throw code for my gearbox bridge port failure so I assume it is okay haha. As for the water pump I did the bleeding with the holding down the accelerator pedal down for 10 seconds method and it runs the electric pump to bleed so I assume that it is fine? (I could be wrong tho) Thank you very much for the response, cheers!
