2006 Bmw 550i oil leaking pretty bad
Old 12-03-2018, 06:19 AM
  #21
audiophool's Avatar
My Ride: 535xi
Possibly, but that filter is inside the housing, and the ring may have slipped out of place when you pulled the filter out. Didn't you see anything else? Was the filter cap tight? Drain plug tight?
Old 12-03-2018, 06:50 AM
  #22
hardnard3's Avatar
My Ride: 2006 Bmw 550i
Everything was tight. I didn’t see any oil leaking around alternator bracket also. I remember when it first happened I saw oil running down the side of oil filter cap
Old 12-03-2018, 09:40 AM
  #23
audiophool's Avatar
My Ride: 535xi
Well then, your only option at this point is put a new oil filter in and re-fill the oil. Then start the engine and check for leaks. That said, it's possible the filter cap is cracked and you can't see it but the crack opens under pressure. Based on how much came out and how fast, I don't see what else it would be. Do you have the proper tool for removing the filter cover or did you use an alternate method such as water-pump pliers?
Old 12-01-2020, 02:17 PM
  #24
Dr_F's Avatar
My Ride: 2008 BMW 550i w/M Sport Package
Engine: N62
Was there a resolution to this oil leak?
Old 12-01-2020, 03:34 PM
  #25
seanjordan20's Avatar
My Ride: 05 530i M54
Model Year: 05 530i
Engine: 3.0 M54
I'm pretty sure there was. These cars leak in many places. You have to figure out where yours is leaking at the time.
Old 12-05-2020, 11:51 AM
  #26
Dr_F's Avatar
Engine: N62
If it helps anyone, my massive oil loss was due to a cracked oil filter cover. Root cause for the crack unknown. This oil filter cover is 13 years old.
Old 12-05-2020, 07:09 PM
  #27
Model Year: 05 530i
Engine: 3.0 M54
Not common. That is an aftermarket so it's not 13 years old
Old 12-05-2020, 07:48 PM
  #28
Dr_F's Avatar
Engine: N62
Why do you think the filter cover is not the original?
Old 12-05-2020, 10:13 PM
  #29
Model Year: 05 530i
Engine: 3.0 M54
Because of the icons on the top. That is a Chinese knock off
Old 12-05-2020, 10:36 PM
  #30
donpb's Avatar
My Ride: '06 530i N52
Yep that looks like Hengst brand.
Quick Reply: 2006 Bmw 550i oil leaking pretty bad
