2006 550i Active Steering Malfunction, DBC Malfunction, Start Off Assi
Old 11-06-2011, 09:00 AM
Joe550i's Avatar
My 550i has done this for a while now and I don't know whats causing it. There are no error codes stored in the system because as soon as I turn the car off, and turn it back on, they go away and done come back till the next day. Most of the time it will just be the active steering malfunction, but sometimes all 4 come up. From my research, the culprits can be the following
1. Wheel alignment ($60)
2. Wheel speed Sensors (over $200)
3. Steering Angle Sensor (almost $1000 to replace and reprogram)
Repairs I have done so far to the car,
1. Replaced battery with BMW black AGM battery
2. Replaced IBS sensor
3. Had the dealer register the new battery (they did a retrofit for the AGM battery)
4. Had the dealer reinitialize active steering angles
What has be confused is that it doesn't do it all the time. Just sometimes. Anyone els have this problem? What fixed it?
Here is a pic of the i-Drive showing the error messages
Old 11-06-2011, 04:25 PM
phlfly's Avatar
My Ride: 07' BMW 550i
you might want to go and get real codes.
Old 11-06-2011, 06:39 PM
Joe550i's Avatar
Ive tried. When I went they said there are no error codes stored in the system! Thats whats driving nuts!
Old 11-06-2011, 06:47 PM
mwolfe's Avatar
What was the car running like when the errors showed up?
Old 11-06-2011, 07:04 PM
Joe550i's Avatar
Car runs fine, the steering wheel tightens up sometimes after the errors show up but goes back to normal if I turn off the car for 5 minutes and turn it back on.
Old 11-06-2011, 07:06 PM
Shlooky's Avatar
My Ride: 545i
it could be a low battery issue?
Old 11-06-2011, 07:09 PM
Joe550i's Avatar
Not a low battery issue. Please read the first post. The battery is 4 days old. This problem is a year old.
Old 11-06-2011, 07:57 PM
phlfly's Avatar
Did you rest battery on computer?
After chatting with BMW service adviser, he is kind a friend, he told me I had a low battery codes safe on car computer. I told battery was reset,but we fogot clear code in my other friend shop.
Old 11-06-2011, 08:01 PM
jaycal3's Avatar
My Ride: 04' 545i, Sport Package, Black, Active Xenon, ARS, Aux Input '10 Tahoe, Black on Black, leather, Nav/XM, 20" tires, full body kit, power 2nd row, loaded '93 Jeep Wrangler, lifted 4.5", 33" meats, Rampage Recovery Bumper w/Tire Swing, etc 25' Aquasport Osprey, Center Console,2012 200 HO Etec
Has your car taken on any water? Is the passenger floor wet at all? I only ask because I got the same error messages (minus the start off assist since I don't have that in my car) after my storm drains clogged and the water backed up into the passenger compartment. Many of those modules and sensors are located in the passenger floor under the rug. If not and you have already replaced your battery, and its not storing codes, maybe you have some type of short or idrive issue?
Old 11-06-2011, 11:01 PM
Joe550i's Avatar
I live in sunny California, no water ever inside. If the errors came on and didnt go away, they would be easy to diagnose and fix, but they dont come on all the time. Sometimes it will go for weeks without the errors showing up again. It annoys me more than anything.
Quick Reply: 2006 550i Active Steering Malfunction, DBC Malfunction, Start Off Assi
