2006 550 creaking
My Ride: 2006 550 SMG
I have 2500 miles and I have noticed creaking in my car. Im sure that these damn run-flats have contributed to most of these. I have read about the door seals. Shouldnt my car already have the new and improved door seals, its an october 06 build. Also, what do the door seals consist of, do they go around the perimeter of the whole door? Other than the creaking, no problems at all. I love this car!!!
Do you find the creaking most noticeable at certain temperatures or is it noticeable on a constant basis?
I have the updated door seals installed and find that my car "creaks" at or near freezing only.
Why do you think the runflats have contributed to the creaking ? Hard ride ?
[/quote]
Yes, the runflats are like metal boots. It definitely gives the car a harder ride.
Banned
When the temp go down in the winter, you're bound to hear noises that you didn't before. Parts expand/contract, and soft part become more rigid, resulting in more noises than during warmer months.
I have found that it creaks more when it is colder outside. Problem is that I never had this problem with my 2002 E39. One creak seems to be coming from the left side of the windshield, is there a remedy for this?
My Ride: 2006 550i Titanium Silver, Black Dakota Leather, Aluminum Cube Trim, M Sport Pkg, Premium Pkg, Comfort Access, Head Up Display, Steptronic, Comfort Seats, Rear Heated Seats, Through Load, Park Distance Control, Navigation , HK Logic 7, etc
[/quote]
Wrong! WD-40 is actually a cleaner, not a lubricant. There are other better products to do that job.
The WD means water displacement. It does have a lubricant properties which is why it stops squeeks and releases rusty nuts and bolts.
However, being a petroleum distilate, I would not use it on my car's leather or rubber surfaces.
I would use a good rubber/leather cleaner, followed by a silicone lubricant applied using a cloth.
Why we should have to do this on an E60 beats me but I am getting a sore head from running the radio too loud!!
Streak
Streak
seals in particular the felt strips then another wipe round with a wet cloth to remove excess lather. This was followed by using an old towel to dry off the seals and three weeks later No Creaks!
