2006 525i Crankshaft and transmission codes 2A94 and 51A7
Old Jan 10, 2023 | 11:32 AM
purplegrog's Avatar
My Ride: 2006 525i
Default 2006 525i Crankshaft and transmission codes 2A94 and 51A7
I have a new to me e60 2006 525i that came to me with codes for the crankshaft position sensor and the transmission in limp mode. Based on the codes it had, I changed the crankshaft position sensor, cleared the codes and tried to start the car. Initially, the car wouldn't start at all, and would just crank with no start. eventually after I tried starting it and pumping the gas while it cranked, the car started back up, but I get the same condition - rough idle, transmission in limp mode, error codes back.
Where should I go from here from a troubleshooting perspective?
Using INPA I have the following errors stored in memory:
2DED (I believe this is from the battery tender I have on the car between times I'm working on the car)
2E8E (Likely from disconnecting the IBS cable while I troubleshot the crank, no start condition)
2A94
5187
Old Jan 10, 2023 | 11:52 AM
twh's Avatar
twh
My Ride: 2006 BMW 530xi 6MT
Engine: N52
Might be some of the emission hoses back there. If you changed the crankshaft position sensor, you probably had the intake off and all the emission hoses undone. Those hoses are very breakable and any leaking or not hooked up right will cause the car to idle like crap even to the point of conking out.
Old Jan 10, 2023 | 12:14 PM
purplegrog's Avatar
My Ride: 2006 525i
from what I can see hoses are all intact. I was able to swap the sensor by going in from underneath, so I didn't touch any of the hoses, intake, etc.
Old Oct 28, 2023 | 08:33 PM
nbbmw's Avatar
hi purplegrog,
you went in from Underneath??? I have a 2007 530xi. you mean you removed the alternator and stuck your arm in there to remove the sensor? can you please describe what you did?
racerx2000
E39 Discussion
Mar 31, 2022 12:00 PM
Deividas Paulauskas
Jul 15, 2021 12:53 PM
Jude Moore
Oct 12, 2019 05:40 PM
gm525i
Nov 27, 2014 06:28 AM
luther99
May 9, 2013 04:59 AM
