2004 E60 530d Turbo Replacement
The turbo has gone on my 2004 530d, I have 2 possibilities for replacement:
1. Genuine BMW parts
2. BTN Turbo
The price difference is just over ?300
Any recommendations or experience of this problem?
2. BTN Turbo
2. BTN Turbo
2. BTN Turbo
You'll also get 2yr warranty if BMW do it.
2. BTN Turbo
2. BTN Turbo
did you check the engine breather, they say if blocked can lead to permature failure of turbo. and how ofter was the oil changed.
i would say get an independant bmw specialist to do the work as dealer charge ?120 or so an hour.
good luck . there are a few post on here with same problem as you.
Originally Posted by Rislar' post='975523' date='Aug 13 2009, 10:56 PM
Bloody hell, what a first post!!! as above can we have some more details?
FSH, next oil service due in approx 5k & microfilter in about 2k
Nothing displayed on the dash at all & no errors on the i-drive
Full dealer history in the first 3 years, independant thereafter. I was thinking of contacting BMW but was unsure how to go about it as the car is in a local garage at the moment. From what I've read seems a fairly common problem around this mileage!!
2. BTN Turbo
2. BTN Turbo
Originally Posted by speedysquires' post='976184' date='Aug 14 2009, 07:37 AM
56k Miles
Originally Posted by stevegarry0' post='976408' date='Aug 14 2009, 03:24 PM
hi... i have 2003 530d e60 and the swirl flaps fell into the engine, the main dealer took the car in and did the job . thay also replaced the turbo and manifold as thay are prone to cracking.. thay did the job as a goodwill geasture think in total it came to 8k i payed ?1500.. my car had 93000 with full history so you should try to get them to pay towards doing it as you have way less miles than me & at the same time replace the inlet manifold as thay have modifiid the new ones with plastic swirl flaps that dont destroy you engine when thay fall off, and its only a mater of time b4 thay do....... steve
Not happy I called Sytner Nottingham & was told bring it in & they will look at it straight away & that they can start work on it on Monday, what a difference. Only problem is I will have to get the car towed in.
Anyway question is what are my chances, the car has full history 1st 2 stamps are a dealer the rest independants. Do I go to the stealer & wait out for a good will gesture or cut my losses & leave with the local garage to be repaired?
tom333
04-01-2015 01:56 PM
