2004 BMW 530i E60 - Non Logic 7 - Hifi - Factory Upgrades - Help
My Ride: 2004 BMW 530i
Hello everyone,
I have spent too much time on this forum and I wish there was a sticky for these basic questions.
I own a 2004 BMW 530i with no Logic7. I assume it is a hifi system because I have speakers in the front door (one tweeter/mid each), one speaker under each front seat (I can't see it but I am 90% sure it's there), and two rear speakers. I also have bass/treble control in my idrive.
Question 1: The factory amp has a complicated crossover/channel setup. I am told upgrading this amp will boost power to the mid range subs underneath the seats. Is that true? If so, which AMP should I buy that has the correct channels/power for my setup? And is there any special customization of frequencies/crossovers required or is this handled at the speakers?
Question 2: Is there a wiring harness available on Ebay so that I can easily install my JL audio 10 inch subwoofer? (I bought this sub, http://www.ebay.com/itm/JL-Audio-CP1...item461a07c642) along with this amp (http://www.ebay.com/itm/NEW-JL-AUDIO...item233ce2e5eb).
Question 3: I am aiming this enclosure to the front thru the ski door. This should be adequate for bass. Is the AMP upgrade in question #1 a good value? If so, can you guys please recommend how I should upgrade the factory amp?
Someone with a lot of experience should chime in.
My Ride: 04 530i
I left the factory amp when I added a jl audio 500/1 and a W3v2 10 and it was fine! I just slightly turned down the bass on the stereo and the sub made up for it!
@akgolfpro, Thanks!. Which box did you use and how much rattling was there? Did you aim it thru the ski hole? Is it quite loud in the cabin with that setup?
Tsoup
15
12-20-2021 11:14 AM
Mihainede85
03-11-2015 09:45 PM
