09 528i CRANKS BUT WON'T START 😟
My Ride: 2009 BMW 528i N52
Model Year: 2009
Engine: N52
Hey everybody I need some help! My 09 528i is usually a delight to drive, but every few months it gives me a new challenge. On my way to lunch the other day, it was driving along beautifully and then suddenly just cut out. No sputtering no backfiring and no intermittent stalling, it just completely shut down in the middle of the road. Tried restarting it several times, and it would crank but not start. I did not have any diagnostic tools on me so I couldn't do much except call for the tow truck which showed up 2 hours later. Once at home, I scanned the car but got no codes. I put a charger on the battery just in case, then sprayed some starting fluid into the intake and it fired up briefly so I assumed the crank sensor was good. Just to be sure I pulled one of the coils, inserted a screwdriver and had a friend crank the car and I did get a spark. I then disconnected the fuel hose from the fuel rail and cranked the engine again, but the fuel barely trickled out. Since the fuel pump was original, I assumed that it finally given up the ghost, so I ordered a new fuel pump and installed it. Cranked up the car, and it would not start again 😔.I rescanned the modules with a BMW specific launch scanner and this time I got a code 651B EKPS Suction Jet Pump malfunction. After doing some research and removing the pump again, as well as the filter unit on the driver side, I discovered that the fuel levels were uneven and that the passenger side where the pump is had very little fuel in there. I added some more fuel to the tank on that side, cleared the codes, cranked the car again. It would not start, but I did not get the same code back this time. I pulled the fuel hose off the fuel rail, and cranked it one more time to see only a trickle of fuel. I activated the pump using the scanner, and the volume of the fuel increased. I scanned all the modules again with INPA - again no codes. I activated the pump with INPA, with the same results, more fuel, but the car still won't start. I was thinking it may be a bad EKPS module but both INPA and the Launch BMW scanner seem to communicate with the module without problems. My scanner does not show the fuel pressure reading at the fuel rail, and I could not find any function on the INPA screens that shows fuel pressure. Just the pump activation showed a full green bar at 100%.
At this point I am really stumped and would welcome any help and suggestions. 🙏🏼
My Ride: 05 530i M54
Model Year: 05 530i
Engine: 3.0 M54
I'm thinking the module also but you need to get the pressure reading. You should be able to find that in the DME. Was just the pump replaced or the assembly. Before replacing another part you need to isolate the issue
My Ride: 2012 BMW X5
If your fuel filter is clogged, the return line won't feed the jet pump and the right tank goes empty. Also the car won't get enough fuel pressure. You need a fuel filter, probably.
If you have replaced the filter, I would look at the Supply fuel pump. It was way over worked with a clogged filter.
Model Year: 2009
Engine: N52
Still no start!
Thanks for the replies!
I did change the pump, but car still won't start! I thought it might be the EKPS fuel pump control module, so I ordered an aftermarket one off eBay, which was a total waste of time! Neither my BMW scanner nor INPA could even see the module at all, so I couldn't program it. I finally got a couple of EKPS modules from the junk yard, coded them to my car, and still no-start.
I can run the pump using the BMW scanner or INPA, but pressure is still low.
Now I'm getting 2 codes after cranking/no-start.
651B - Suction Jet Pump Malfunction
6294 - EKPS Control current Too Low
All other modules show OKAY and no related codes.
Now I'm thinking that the leaking left/side filter assembly that I replaced a few months ago with aftermarket part has failed. There's not a lot of forum info about this, but apparently this assembly has the pressure regulator and a jet pump (to return fuel to right side of tank) built-in, and if it has failed, might be causing the loss of fuel pressure and uneven fuel level between the left and right sides of the tank.
I can't find any other causes, so I will try replacing it with a Bosch unit.
LMK what you all think...
Model Year: 05 530i
Engine: 3.0 M54
You're using aftermarket and not OEM? Things that make the car run should not be aftermarket because they can run you in circles when issues arrive.
Model Year: 2009
Engine: N52
Aftermarket
BTW, I have successfully used quality aftermarket parts on other cars, and some have lasted for years. Many "OEM" parts are now made in China, Malaysia or Thailand. I recently orderered an NTK brand oxygen sensor for another car, and even though NTK is a division of NGK, the sensor was made in China instead of Japan, and worked fine.
Model Year: 05 530i
Engine: 3.0 M54
The point I was trying making is that a BMW is a different animal. Anything aftermarket that makes the car run is a crap shoot because of all the computers. I do use aftermarket on many cars but there's certain parts on a BMW I don't buy aftermarket. Not that they will not work it's because you don't know what will agree with it. I've had many customers buy aftermarket parts just to keep having the same issue running them in circles. Replace it with OEM problem solved. My rule of thumb is if it makes the car run buy OEM and it hasn't failed me yet. Again there's nothing wrong with aftermarket you just have to know your audience.
Model Year: 2009
Engine: N52
09 528i e60 n-52 cranks but won't start - solved!
When I first researched my no-start problem, I found very little info about the fuel delivery system on the E60 N52 cars. I also barely received any helpful replies to my posts regarding the no start issue. Hence I will share my experience, hoping it will help others.
So, if you have a no-start tissue, but have a spark, and the car won't start, then if:
A. You have barely any fuel pressure at the rail.
B. The fuel pump runs, and can be turned on using a scanner or INPA
C. The EKP module is OK, and the scanner can communicate with it.
D. The left (driver's side) of the car has way more fuel than the right side
Then, your filter module is probably defective. This module has a pressure module, jet pump and a fuel level sensor built into it. The fuel is pumped to this module by the main fuel pump located on the right half of the fuel tank. The filter assembly on the left side modulates the pressure, then sends fuel to the fuel rail at the specified pressure (around 72psi) Excess fuel is sent back to the right side side via a jet pump and plastic hose within the tank. Hence if the pressure regulator fails and/or the jet pump fails, then fuel pressure at the rail is too low for the car to start. And if the main fuel pump is working properly, then all the fuel ends up accumulating in the left side of the tank and the right side is virtually empty.
If the pump or the filter assembly haven't been replaced in a while, its probably better to replace both at the same time with Bosch parts to help avoid future problems
