5Series.net - Forums
-   -   08 535i rear differential fluid change (https://5series.net/forums/e60-discussion-2/08-535i-rear-differential-fluid-change-142963/)
aznfujikiddd Sep 10, 2015 12:02 PM
I went under my car I only see 1 drain hole, so what kind tool to suck the oil out and fill?
KyleB Sep 10, 2015 12:43 PM
I got a universal use fluid pump from harbor freight, looks like this:
Multi-Use Transfer Pump
jtbgonesailing Sep 10, 2015 12:44 PM
You should have 2 plugs in the differential. One on the passenger side, fill, and a drain plug towards the bottom of the rear cover plate. The drain is nestled in amongst the alunimum cooling fins.
DanL Sep 10, 2015 03:32 PM
Not on an '08 535i.
aznfujikiddd Sep 10, 2015 03:42 PM
Thank you , I'll check it out.
