07 550I transmission fault after upgrades
#41
My Ride: 05 530i M54
Model Year: 05 530i
Engine: 3.0 M54
Seems you still have an issue with a connection or solenoid. Below are some of your issues:
9c55 condensation sensor under rear view
A3AA Transmission Module Communication Error
AB01 Input, selector-lever position, implausible
E18F battery needs to be registered
D358 No message Transmission receiver DSC transmitter ESG/SMG
2DCA CAN Timeout EGS
#42
My Ride: Silver 07 550I E60 automatic
Engine: v8
#43
Engine: v8
#44
Model Year: 05 530i
Engine: 3.0 M54
I got a trans fault. Never looked at the codes nor drove it out of the garage. I knew it had to be the connector so I worked at it until it went a little further and that worked.
#45
Engine: v8
#46
My Ride: E60 2006 sedan auto
I have always done it based on the tranny pan
I also have the rear slightly higher
I personally would rather a little more fluid than not enough
Also remember the gear changes will be rough and hard for a little while till the computer works it all out
#47
Engine: v8
I've read your posts where you say sometimes 100 to 200 miles after resetting adaptations, but have you ever experienced transmission malfunction during that time or just hard rough shifting?
#48
OP, if you have reset the transmission adaptation, here is the ZF official relearn procedure. Go gentle on the transmission while it is relearning the values.
https://www.bimmerfest.com/forums/at...4&d=1529145938
#49
I would take the advice of ensuring your electrical connections are all perfect which could be your problem now since the transmission is pumping fluid and is full
After resetting the transmission it can sometimes slam into gear when it changes
This could cause a fault
Check your connections
Clear your fault codes and drive gently like it's your wife's car
#50
For your review if you have reset the adaptation.
