'07 525i a/c whirring sound
My Ride: 2007 525i
Seems when ambient temps are below 75 or below degrees out, the a/c whirs pretty significantly louder more than normal. Could this be due to lack of improper freon?
My Ride: 545i sport
Probably not due to refrigerant level. Mine is whining as well and it indicates to me that it is time to have the compressor rebuilt/replaced. I am just waiting until I have the time to replace valve stem seals, coolant transfer pipe, heater water valve, and clean the secondary air ports.
My Ride: 14 550i
I agree it could also be your Compressor going out. If it is coming from the cabin it is possible it could be a blower motor also, but since you mentioned while AC is on the compressor makes more sense.
My Ride: 2007 525i
Blower motor is fine. You can turn the compressor off and it goes away. When it's above 75 ambient degrees out it's fine.
tundra
11-10-2016 06:55 AM
PelicanParts.com
07-23-2015 12:50 PM
