04-06 6hp19 & 06+ 6hp19 Differences
My Ride: 2004 e60 530i
I'm trying to buy a replacement transmission for my 04 530i and It seems to be 2 types of 6hp19 transmissions.
I think it goes down to the torque converters, one has 3 mounting bolts and the other 6.
From the pictures I have found, the 04-06 have 3 bolts and the 06+ have 6.
Having a hard time finding a used on that's for the 04-06, I can find plenty of 06+, but no 04-06.
Do you think, I can just reuse my torque converter from my 04??
BMW has a remanufactured transmission for about $3000, but I wanted to keep the cost on the lower end.
Any info will greatly help me out!!
Here's a link that says 04-07 e60 can use the same transmission.
Does anyone know if they are interchangeable??
BMW E60 520D GA6HP19Z Automatic Gearbox Genuine Warranty | eBay
I'm now beginning to think the differences are the engine m54 vs n52.
It's looking like I need to just buy from bmw or reuse my torque converter or buy a rebuild torque converter.
I bought it for $4500 155K, and didn't want to put $3000 grand on a new transmission, but would rather but $1500 on a used transmission and resell and add that cash for a newer one with lower miles.
What would you do??lol
My Ride: 2005 525i bmw
![Question](https://5series.net/forums/images/icons/icon5.gif)
Were you able to change the 6 bolt to a 3 bolt?
My Ride: 530i
Engine: M54
The biggest differences other than the X-drive gearboxes that I'm aware of are the early M-shift (physical linkage from shifter to gearbox) and E-shift (no physical linkage, 'shift by wire'). Valve bodies are different for sure, not sure what else may be different.
My Ride: 2008 535i Sport
Are you absolutely SURE that you need a new tranny? What are the symptoms? Are you getting any codes? Which ones?
Just trying to save you some $$$. My 06 330i had a harsh clunk shift when the car would shift from 2 to 1 near a complete stop. This progressed to clunky shifts around town. Then finally, I would get a tranny error and limp mode when getting on the freeway briskly or even commanding a downshift via high throttle pressure.
The tranny was a complete mess.
I replaced ALL of the solenoids on the mechatronic unit (valve body) and my transmission was literally like new again. As a side benefit the car shifted much quicker between Park, Reverse, and Drive. I didn't even realize how delayed it was until I replaced the solenoids.
This was at 130k miles. The actual tranny is quite stout. The solenoids, not so much.
Solenoids are a DIY job if you are so inclined. Cost me about $550 for all new ones. Tell us more to see if you can avoid replacing the whole tranny.
I want to put in the 06 is that shft by wire or analog? Is there any n54 drive by wire trans i can fit even if i have to change some parts. The shop is only finding 04's with 165k+ my car just now hit 100k miles. Definitely dont want a higher mileage trans. And can i do an xdrive delete into a rwd only car?
ekb20b
08-11-2008 07:10 PM
