*35i HPFP update
Old 08-04-2010, 10:02 AM
ADD
ADD's Avatar
Thanks for all the replies.
I was not intending to imply that the ethanol was directly related to the HPFP issues, although, I'm sure it doesn't help.
I was commenting more on the stumbling engine response.
I'm sure a lot of people have immediately jumped to "HPFP problem" when they get any kind of hiccup in the engine, as I did when I had the HPFP replaced and the stumble was still there.
I'm just saying that after draining the tank, my stumbling issues were resolved, and apparently not the FP.
Old 08-04-2010, 12:47 PM
bigbadbull's Avatar
My Ride: 2010 VW Passat Wagon 2.0l Tsi Grey/Grey Budapest 18" Lost to HPFP issues: 08 535i sport pkg Lost to Dreaded E61 Sun roof leaks: 07 E61 530Xi
Bosch were the original designers, and they have been using it since at least 2003 in Europe on the VAG gas 2.0lT I4....I have not looked at the new Twin Charged motors to see it was used, but the principle of it comes from the high pressure Diesels that Bosch has worked on for eons...
BMW "Reverse engineered it" and had either Semiens VDO ( they build the newer ones I think) or Valeo built them for BMW. This is just what I've been told when talking to Engineers and Mechanics when at the shops.It's a very sore subject. Also I've heard the joys of changing the plugs on the new TTv8 in the F10's/01/07....PitA to say the least, very much like the same procedure on the old 928's if you have worked on one.
E90post has the trials and tribulations from several owners in Munich and in Scandinavia and other parts of Europe. In Munich they have even taken the cars back to the HQ for tear downs on the pumps to figure out what is going on and how to fix it.
Old 08-04-2010, 12:50 PM
bigbadbull's Avatar
Originally Posted by ADD
Thanks for all the replies.I was not intending to imply that the ethanol was directly related to the HPFP issues, although, I'm sure it doesn't help.I was commenting more on the stumbling engine response.I'm sure a lot of people have immediately jumped to "HPFP problem" when they get any kind of hiccup in the engine, as I did when I had the HPFP replaced and the stumble was still there.I'm just saying that after draining the tank, my stumbling issues were resolved, and apparently not the FP.
Also that happened on #2 of 5 for me. In fact they put another LPFP and set of Fuel Pressure sensors and drained the tank, 4 months later same issue.
Old 08-04-2010, 04:48 PM
Allen's Avatar
My Ride: 535i 6-speed
So what is the latest on the HPFP anyway...I know there have been several iterations/revisions to date. Have they created one that is working?
Old 08-04-2010, 06:08 PM
Gene's Avatar
nope..not yet....
Old 08-04-2010, 06:23 PM
njlou's Avatar
Originally Posted by GENEaTALS
nope..not yet....
This entire subject is so intriguing from a technical view. I know that BMW is best to keep their mouths shut on the details, but I have never read exactly what goes wrong.
You would think that some speculation or some real data would emerge.
Does the pump not pump enough, or does the electric motor quit, or does pressure back up into the pump???
And what is the low presure pump situation?
I understand that the HPFP is fed by a LPFP??
AND why dont they fix it??
Old 08-05-2010, 10:03 AM
bigbadbull's Avatar
I know some have created a "lean" sustained lean situation that causes the Injectors to fail prematurely. A full set can run like $3k if they are not covered.
There are a bunch of different issues all classified HPFP Failure so it is some what case dependent.
Old 08-05-2010, 11:13 PM
r9ndy's Avatar
My Ride: 2005 545i Black Sapphire - Fully Loaded
Model Year: 545i 2005
I wonder if they have these issues with the f10. Makes me think twice about getting a TT bmw.
Old 08-06-2010, 06:03 AM
Gene's Avatar
different engine and design. The x35 models have the single turbo N55 engine...no HPFP problems reported as of yet...but have read a few threads on X6 and e90 posts forums (the _35 models have the N55 engine as well) of wastegate rattles....
jluzbet
11-07-2015 01:25 PM
Bank$hot530
09-16-2015 01:28 PM
ST JAMES
09-04-2015 04:54 PM
fifthofjac
08-30-2015 07:08 PM
Quick Reply: *35i HPFP update
