E39 Discussion Anything and everything to do with the E39 (1997 - 2003) 5 series!
what do I look for when viewing 525d sport
Old Mar 16, 2012 | 01:43 PM
plumajp's Avatar
i have seen a 2003 525d sport that i fancy having a look at.
its auto with black leather and has been remapped.
are there any common problems I need to look for with these cars? it has high mileage roughly 140k miles
thanks in advance.
Old Jun 18, 2012 | 10:02 AM
Ragtop Steve's Avatar
My Ride: F07 GT 535D M Sport & E60 530D M Sport
Dear Me,,, 108 views and not 1 reply.....
Good job i just popped on,,,,
Have you bought the car yet. ??
I bought a e39 525D 2003 sport around 2 1/2 years ago with 152k miles, i knew the car as it was my old bosses car so when i was aksed to collect the car and sell it i thought,,,, lets have a look hear. After getting a local garage to have a good look i made an offer well below the book price and all he said was take it away.
Things to look out for
Suspension, front and rear, they tend to start going around the 120k mark, the fronts were shagged, and the rears were very sloppy so i decided to replace every thing.
Prop shaft rubber vibration damper, this will defo be warn, so replace it
have a good look at discs and pads, i replaced mine
Leather, the seats are hard wearing, better then other BMW,s that i have owned but look out for the usual wearing on the driver boulster, also look out for tale tell signs like gear knob worn, driver door kick panel accessive wear, and the gear surround gator worn, all signed of it done more miles then it says on the clock or just had a hard life
Check the engine oil,,,,,,if it smell like a dirty oil rag then it needs a change.
Things you need to do, oil and filter change, if its a manual change the gear box and rear diff oil, decat it, defo go for a remap, egr bypass valve, and then enjoy the drive.
I changed the oil every 6k, the crank case breather filter every 2nd oil change. There is no swirl flap,s with the 2.5d so your ok there. Now i just sold mine with 192k miles on the clock and she still looked clean and tidy for a 3003 model.
jfmartin25
Nov 2, 2022 01:42 AM
IRFOMAESTRO
F10 Discussion
Feb 2, 2019 11:22 PM
BEZ101
Mar 10, 2015 06:22 AM
rkilpa
Mar 4, 2015 09:10 PM
