Spec'd Halo Projection Wiring Installation
Probation Members
My Ride: 2003 e39 530i
Good Day folks, I am having trouble with the LH side wiring of the Spec'd Halo Projector Headlamps. Specifically with the Turn Signal. Mine has 3 wires coming from the turn signal. The RH side works fine, but when I try the left hand side turn signal, it also activates the RH side. I have attached pictures. Maybe the answer is glaring me in the face, but I am unable to troubleshoot (cant see the forest for the tree's). Thanks in advance.
This is my troublesome side (LH). 3 wires coming from turn signal.
This side (RH) wiring seems to work fine.
