N52 Oil Filter Housing LEAK - REPLACED Gasket and still leak?!
My Ride: 2008 528i, Black Sapphire, M5 front, 2piece Niche Touring II, Nitto Invo, H&R
![Exclamation](https://5series.net/forums/images/icons/icon4.gif)
Hi guys,
Over the weekend I replaced my Oil Filter Housing Gasket (DIY) as per BMW saying I had a leak. I bought the gasket online installed it Friday. HOWEVER, I still have a leak!?
Below is a picture of where the oil is pooling up. If it's not the housing gasket, what could be the cause? Any help would be greatly appreciated.
imgur: the simple image sharer
![Crying](https://5series.net/forums/images/smilies/imported/crying.gif)
well i plan to get this going as well, in the meantime i was waiting for your results. but i checked on BMW Parts and BMW Accessories | Bavarian Autosport for the gaskets, there were two types (see below).
Gasket - Oil Filter Housing To Engine Block
1.![](http://www.bavauto.com/assets/imglib500/11427537293.jpg)
Gasket - Oil Filter Housing to Oil Cooler
2.![](http://www.bavauto.com/assets/imglib500/11427525335_IMG01.jpg)
Which of the two did you do? or both?![Wassat](https://5series.net/forums/images/smilies/imported/wassat.gif)
How about these replacement gaskets?
Gasket Ring - For Oil Level Sensor
![](http://www.bavauto.com/assets/imglib500/12611744292.jpg)
Gasket Ring - Oil Filler Cap - Located Between Valve Cover And Plastic Coil Cover
1.
2.
![](http://www.bavauto.com/assets/imglib500/11127526447.jpg)
mantraguy
03-09-2015 02:56 AM
