N52 Oil Filter Housing LEAK - REPLACED Gasket and still leak?!
1 Attachment(s)
Hi guys,
Over the weekend I replaced my Oil Filter Housing Gasket (DIY) as per BMW saying I had a leak. I bought the gasket online installed it Friday. HOWEVER, I still have a leak!? :cry: Below is a picture of where the oil is pooling up. If it's not the housing gasket, what could be the cause? Any help would be greatly appreciated. imgur: the simple image sharer |
bump
well i plan to get this going as well, in the meantime i was waiting for your results. but i checked on BMW Parts and BMW Accessories | Bavarian Autosport for the gaskets, there were two types (see below).
Gasket - Oil Filter Housing To Engine Block 1.http://www.bavauto.com/assets/imglib500/11427537293.jpg Gasket - Oil Filter Housing to Oil Cooler 2.http://www.bavauto.com/assets/imglib...5335_IMG01.jpg Which of the two did you do? or both?:huh: How about these replacement gaskets? Gasket Ring - For Oil Level Sensor http://www.bavauto.com/assets/imglib500/12611744292.jpg Gasket Ring - Oil Filler Cap - Located Between Valve Cover And Plastic Coil Cover http://www.bavauto.com/assets/imglib500/11127526447.jpg |
