e39 + NCS EXPERT, dimmed high beam as DRL
My Ride: e39 530dAT
Hello folks, sorry if this is wrong section...
I coded dimmed high beam as DRL to 2003 530dAT with NCSexpert. I changed these settigns:
GED_FL_ALS_DRL - dimmed high beam as DRL --> aktiv
FL_DIMMUNG_ALS_DRL - dimming level for high beam as daylight --> wert03
This is also
AL_ALS_DRL - low-beam as DRL is nicht_aktiv.
I have light sensor (ALS) so xenons go on if surrounding lights go low enough. Normally I keep ligth switch on AUTO-setting. On daylight, I have dimmed high beams on, xenon off, AE off. When I switch light switch to 0 I have only dimmed high beams on. When I put my to parking mode, I have AE on but now also high beams on. Before codings, I had only AE on, other off. When I switch it to low beams, I have AE on, xenon on and dimmed high beams off.
Is it possible to code dimmed high beams on on parking mode? Then I would only have AE on. And I really would like to have all lights of when light switch is on 0 mode.
So is there a way to use only angel eyes when GED_FL_ALS_DRL - dimmed high beam as DRL --> aktiv?
Thanks in advance!
This is also
Thanks in advance!
umnitza
09-02-2015 11:28 AM
spediegunz
08-30-2015 09:43 AM
PelicanParts.com
07-16-2015 01:12 PM
