E39 Discussion Anything and everything to do with the E39 (1997 - 2003) 5 series!
E39 Angel Eyes Strobing
Old Jan 19, 2011 | 05:37 PM
IceyTys's Avatar
Originally Posted by wakes_bmw
Most angle eyes with led's have that problem...
Got something to do with your computer checking all your lights. A normal bulb doesn't show it, but led's do.
Don't sweat it
+1 my license plate lights do that as well. Your car is sending out a small pulse of current to make sure all the bulbs are working, its looking for resistance. The problem with LED is they require very little juice to turn on, the pulse makes them flicker/strobe.
Old Jan 19, 2011 | 05:52 PM
nomis_nehc's Avatar
My Ride: BMW E60
Model Year: 2016
El correcto.
Old Sep 29, 2011 | 09:30 PM
IndiaDrives's Avatar
Banned
I do not think it's actually a kit that can prevent the St-dressing, which has to do with the product itself. There are other variations of the AE brands that do not have cable. Angeli bright and ice on my car are the two brands that come to mind right now .. but other
Old Oct 15, 2011 | 08:56 AM
AchtungE60's Avatar
My Ride: E60 530i
manipulate the computer to stop checking for the bulbs and you can increase the voltage if you have higher wattage LED's so they're super bright. Very simple.
Old Nov 15, 2014 | 03:12 PM
chamisra's Avatar
My Ride: E39 2001
Originally Posted by Jon M5
When he starts his car up with the lights OFF, the angels strobe for about 5-10 seconds, and then stay on normally without strobing. Is there a kit out there which can stop this? Like the V5 for the LCI rear
The E39 performs a cold check on all lamps at start up, standard lamps are unaffected due to the low current pulses. LED lamps pulse during this check which is absolutely normal.
If you leave the lights off and watch closely, each of them will pulse alternately every 30 seconds, this is the warm check.
This is the test the car performs and if one fails then the failed lamp indicator on the dash illuminates.
Your LEDs are fine, no need to change them and definitely no need for a suppression kit.
The only kit you could ever need would be if you get error messages from using cheap lamps which are not canbus compatible.
derooster
Sep 22, 2016 07:30 AM
bestofthebest
Mar 28, 2016 02:47 PM
PMorganRacing
E39 Discussion
Sep 28, 2015 09:49 AM
PMorganRacing
E39 Discussion
Sep 16, 2015 04:01 PM
umnitza
Sep 2, 2015 11:28 AM
