Just bought 92 535i
Yeah everything checked out good just needed to get some suspension work done to it, arms, struts, etc but it runs beautiful!! No problems at all. And I was actually thinking about getting those m5 wheels too.
automatic
automatic
Nice E34. I just got one myself.
Def give the car a good service, make sure everything is up to date and the car is safe. There is nothing worse than having a car broken down with expensive parts because they 'forgot' to do the basics.
Check and/or replace the cap, rotor, plugs & wires. Adjust the valves. Flush EVERY fluid (engine oil, trans fluid, diff fluid, brake fluid, coolant & power steering). Replace the belts and hoses. Check tire pressures. Replace the fuel filter, air filter and cabin filter.
Then start checking other stuff: suspension components, drivetrain bits and everything else. Make sure the car is safe and tight.
Awest91
Sep 17, 2022 11:05 PM
S4CH
May 4, 2015 09:37 AM
