E34 Heater Core Replacement
Just a source in case anyone tries to attempt this DIY:
Winter is getting very near so I can't put this job off any longer. When I bought my E34 the HVAC was pretty messed up. About the only thing that seemed to work properly was the blower fan. I couldn't seem to get any heat when I wanted it yet it would roast me in the summer. Also, the AC doesn't work (next year's project). My car has the dreaded IHKA Automatic air conditioning, which to me seems a bit over the top. It's a computer controlled system that has full control over the heat & AC and where that air is directed via 10 stepper motors attached to plenum doors. The system was used mainly in the E32 but it also made it's way into the E34 and E31. Regardless, the focus of this DIY is changing the heater core, not working on the IHKA system. I know many people in North America don't have the IHKA so there will be differences in a few of the procedures. I hope this post helps those without IHKA to change their heater cores as well.
The heater core on the E34 was much better thought out by BMW compared to the previous two generations of 5 series cars, On the E12 and E28, the entire air condioning evaporator box must first be removed before accessing the heater core. This meant discharging the AC refrigerant and charging it after the work was done. Now on the E34 the heater core sits in behind of the evaporator instead of in front of it and is no longer buried. The entire center console must be removed from the car before getting to the core. Overall the job is easy, the hardest part being the center
console removal and re-fitting. It?s time consuming, it took me about 6 or 7 hours (and another 5 hours to write this!) so plan on a full day. I also did a few other side jobs like installing a new heater valve and played with the sword so that pushed the time up. Shogun has a write up on the heater core R&R that is very good but is lacking pictures. I didn?t find any other DIYs on the heater core R&R for the E34 so I decided to make one. Maybe there are write ups out there, I didn?t see any. I loosely followed Shogun?s instructions when I did mine, thanks Shogun for the help and inspiration.
Apparently, there are two different types of heater core for the E34. This DIY is for the early version of the core. If your car was built January 1990 or later you may have a different heater core than what's shown here. Procedures for the different cores may or may not be the same....IDK.
Check your build date and see what version of core you have by entering the last 7 digits of your VIN at RealOEM.com
http://www.realoem.com/bmw/select.do
http://i29.photobucket.com/albums/c2...A/DSCF1075.jpg
Center console removal:
We start in the back seat. It would be a good idea to pull the back seat and disconnect the battery. I did mine with it connected but it would be safer to do this job with the battery disconnected. A poor stereo install by a previous owner may have wires exposed which could short. Also there is less chance of damaging something expensive, like the OBC. Remove the rear cover on the console by prying out the bottom of the cigarette lighter panel. If you pry on the top you risk busting some plastic clips. Detach the lamp and wires from the cigarette lighter.
http://i29.photobucket.com/albums/c2...A/DSCF1077.jpg
With the panel gone you'll see 4 screws. Two are hex head and 2 philips head. With a 8mm socket or wrench remove the two hex head screws.
http://i29.photobucket.com/albums/c2...A/DSCF1078.jpg
Pry up the rear of the parking brake handle boot to release a plastic clip. The boot is hooked on the front so pull the boot back to release that. You will find a hidden screw under the boot. Remove it and the screw in the tray from the forward portion of the rear console. The rear half of the center console will now be free. Pull the parking brake boot over the handle (so it's inside out) to make it easier to feed the base through the hole. Next we go after the front part of the center console.
Slide two fingers in under the window switch cluster and push up. Disconnect the wiring harness. Do the same for the emergency flasher switch.
http://i29.photobucket.com/albums/c2...A/DSCF1089.jpg
Parking brake ON! Or block the wheels. Remove the ashtray. Remove the shift knob. Automatics have a small set screw on the handle that needs to be removed before it can be pulled off. Remove the shifter surround by lifting the front to release two clips. You'll need some sort of tool that will hook the panel and lift. You shouldn't have to pull hard. Don't pry at the rear of the panel or you'll bust plastic hooks.
Disconnect the wires to the transmission switch. For a auto, put the transmission in 1st gear to make the console removal easier.
http://i29.photobucket.com/albums/c2...A/DSCF1080.jpg
On both sides of the console are decorative trim pieces, remove both revealing four screws. Remove the 4 screws.
http://i29.photobucket.com/albums/c2...A/DSCF1079.jpg
Remove the driver underdash kick panel. There are three screws along the top. There are two plastic clips on the firewall. To remove the clips give them a ¼ turn to release. There are 3 screws holding a plenum duct to the panel. Remove these three as well or you will have trouble getting the panel out.
http://i29.photobucket.com/albums/c2...A/DSCF1081.jpg
Remove the glove box. There are two hinge clips at the back. Lift the lever to release them. The two straps are held on by spring clips. A small flat screwdriver will be needed to release the lock on the clip and slide them off. Remove the two carpeted panels from the transmission hump (one each side) that are held on with 1 screw each.
http://i29.photobucket.com/albums/c2...A/DSCF1083.jpg
Above the glove box and next to the center console is a plastic cover. It will need to go. Remove the 1 screw and the plastic retaining clip as shown in the picture. Then remove the connector for the flashlight from this panel, it?s just snapped in.
http://i29.photobucket.com/albums/c2.../DSCF1091a.jpg
There is 1 screw on each side of the center console attaching to the heater box, remove these.
http://i29.photobucket.com/albums/c2...A/DSCF1084.jpg
There will be a screw on each side of the center console up high. One hidden by the glovebox and one under the instrument cluster. Remove these as well.
http://i29.photobucket.com/albums/c2...A/DSCF1086.jpg
Remove the IHKA control panel by prying out the left side. Once the left side is out the right side can be unhooked. Disconnect the two wiring connectors from the back.
http://i29.photobucket.com/albums/c2...A/DSCF1085.jpg
About now the center console should be pretty much free to come out. Keep in mind there is still the wiring connector for the cigarette lighter. If you know you can remove the stereo now without fuss, do it. At the rear of the console is 1 fastener that will need to be removed.
http://i29.photobucket.com/albums/c2...A/DSCF1088.jpg
Once the console is lifted above this stud it should be free to slide backwards. The panel for the stereo and OBC will stay behind. With the console moved back you should be able to reach you hand in and fish out the connector for the cigarette lighter. Disconnect it. Now it?s a matter of figuring out the secret position to allow the console to be removed
from the car. For me it was parking brake on hard, seats back fully and I wiggled it out the passenger side. With the center console removed, pull and remove the heat duct from the transmission tunnel.
Also it would be good if you could remove the stereo and OBC so they are not in your way (because they will be).
Disconnect the harness connector from the back of the OBC frame to free it up.
Heater core removal:
Disconnect any wires that may be in the way for pulling the large cover. At each side of the bottom is a mounting bracket. A 13mm wrench or socket will be needed to remove these. With the bolt gone remove the Philips head screw and remove both brackets. The cover is now held on by 6 small steel spring clips. Four clips along the top and one on each side. The picture shows the locations.
Cut any zip ties that attach the various harnesses to the cover
http://i29.photobucket.com/albums/c2.../DSCF1101a.jpg
With the cover off you now see the heater core and it?s associated plumbing. Hot coolant flows into the right or left core from the sides and the center pipe is the return. You?ll now need an 8mm socket to remove the screws, a pair of pliers for the spring clips, a container to catch coolant of at least 500ml or 750ml in size and lots of paper towels to
catch any spilt coolant. It should also be noted the engine should be cold with no residual pressure built up in the cooling system or else you will be in for a nasty surprise (and the chore of cleaning your interior). I didn?t drain the cooling system on my car before performing this. I also left the cap on the reservoir to vapor lock it and prevent the entire cooling system from draining into the cabin. I should also mention that several months prior, I removed the heater valve from my car and plugged those three lines. So, at the core, the two outside lines were plugged on the
other side of the firewall and the center return line was still connected to the cooling system at the engine. Once I cracked open the pipes I had about 250ml drain out then it stopped.
http://i29.photobucket.com/albums/c2.../DSCF1104a.jpg
Start by removing the bolt & nut that connect the aluminum pipes to plastic. Have the container in place and split the joint open. Let it drain while you remove the spring clips and 8mm bolts from the pipe flanges. If you start getting excess coolant draining (more than ½ litre) you might have to stop operations, close it up while you drain coolant from the car. So proceed slowly and watch your container to make sure it doesn?t overfill. Alternatively, you could pinch off the feed and return hoses in the engine bay. They make a style of clamp for hose that looks like a pair of vise grips but with rounded jaws so it won't damage the rubber. Or if you were really desperate, you could use a C-clamp to pinch off each hose.
http://i29.photobucket.com/albums/c2...A/DSCF1107.jpg
http://i29.photobucket.com/albums/c2...A/DSCF1108.jpg
If it dribbles a bit and stops then pull the flanges off the top of the core. A little more may drain at this point. Remove the twin plastic pipes from the car. If all is still good, proceed to remove the feed pipe for the drivers side core. Remove the one bolt and give the flange about 1/8 turn to unlock it as shown in the pictures.
http://i29.photobucket.com/albums/c2...A/DSCF1110.jpg
http://i29.photobucket.com/albums/c2...A/DSCF1111.jpg
As you pull the left feed pipe off the core you?ll get a little more coolant spilt. Paper towels may be needed here. Cover the carpet with them to catch anything residual. With all three pipes disconnected from the core you can remove it by swinging the passenger side out first. Make sure the left pipe is pulled out of the core far enough so it doesn?t catch
& bend. Keep in mind the core is still full of coolant so it must be kept upright at all times until you get it out of the car. Some paper towels over the holes may help prevent spilling on the seats or carpet while removing.
http://i29.photobucket.com/albums/c2...A/DSCF1112.jpg
Remove the core from the car and drain it. Clean the heater core cavity well if you have had leaking coolant. The smell can persist for some time if it was left. On my heater box there are drains on both sides (for coolant I?m assuming).
Ugh! Looks like I have some investigative work to do. The coolant in my heater core had engine oil!!! Looks like I may be doing a headgasket DIY in the near future. I suspected that one side of the core was plugged. That plus the heater valve on one side was seized. A big viscous lump of grey schmeg fell out of one of the pipes when I removed them. Flushing the old core also shows water wasn?t getting through on one side. Flush the plastic pipes before re-installation.
http://i29.photobucket.com/albums/c2...A/DSCF1109.jpg
The old heater core will have 5 square nuts attached by the flanges. Make sure you don?t lose these when draining coolant into the pail. You?ll need to transfer these to the new core.
http://i29.photobucket.com/albums/c2...A/DSCF1113.jpg
Installation:
The new core comes with foam strips, O rings, a partition and instructions. I bought mine from a Worldpac source and paid $200 shipped to my door (Canadian dollars), it should be about $170 to buy in the US. I was expecting a cheap Chinese copy but when I opened the box it had Behr written all over it so all is good.
http://i29.photobucket.com/albums/c2...A/DSCF1106.jpg
Start by placing the medium length foam strip across the back.
http://i29.photobucket.com/albums/c2...A/DSCF1114.jpg
Place the short foam strip over the top of the center flange.
http://i29.photobucket.com/albums/c2...A/DSCF1116.jpg
Flip it over and install the partition. Install the long foam strip on the bottom and both sides of the core.
http://i29.photobucket.com/albums/c2...A/DSCF1115.jpg
O rings:
The new heater core comes with O rings. In my case, they weren?t all supplied. On my car I had 7 O rings total. Luckily, I had a kit of O ring assortments here and was able to select ones that fit. You won?t want to risk re-using the old O rings because the may be dried out and cracked. Also, by now they are probably now called ?square rings? from being compressed for so long.
O rings can be bought cheap from the dealer. Here?s the part numbers.
http://www.bmwmobiletradition-online...ams/e/h/19.png
Item 9 = 64118379131 (20.29mm Dia)
Item 8 = 64111374238 (13.98mm Dia)
Item 18 = 64111355780 (17.12mm Dia)
The two O rings on the plastic pipe elbows are not listed But I?m pretty sure they were the same size as Item 18. I had a small leak at one of these joints so I replaced all the O rings with new.
Drop the 5 square nuts into the slots behind each of the flanges and keep the core upright from now on. Slide the core into place behind the left coolant pipe. Note it will be harder to push in because you?ll be compressing the fresh foam.
http://i29.photobucket.com/albums/c2...A/DSCF1117.jpg
Once it?s in, pull it back to mate with the left coolant pipe. Once you?re confident the core is correctly fit, start attaching the plumbing making sure O rings are present at all joints. With everything attached and lining up you can now attach the spring slips on the pipes and tighten down the flange bolts.
http://i29.photobucket.com/albums/c2...A/DSCF1118.jpg
Now would be a good time to top off the coolant in the car and start it up. When I did this job on my car I drained out about 750ml from the pipes and core. I also installed a new heater valve so I?m guessing about another 250ml for that. So I was low about 1 full litre. If the coolant you drained is clean, pour it back in. If it has a bit of dirt & bugs in it and you want to re-use it, filter it with a funnel and a paper towel. The HVAC control panel will need to be plugged in temporary to make the system come alive. With the cap on it should build up pressure so you can see if any leaks develop. It would be much easier to deal with any leaks now rather than having to do it all over again. With the car running you can check for flow on both sides of the core. It should quickly get warm. Bleed air from the cooling
system if it needs it.
With the core in and no leaks it?s time to install the cover.
Re-installation is basically the reverse of removal. Don?t forget to re-attach any electrical connectors you may have pulled. Zip tie the harness back where ever it was attached before.
Enjoy!
I know these instructions are not for everybody. Those without IHKA will have a few different procedures to follow. If anybody wants to add more to cover different cars, please feel free to do so.
Thanks for reading my long winded DIY
Trevor M
1978 633CSi in Fjord Blue Metallic, 1987 635CSi Euro in Diamantschwarz Metallic, 16" BBS RS, 1989 325iX
1989 ALPINA B10 3.5 in Alpineweiss II, 1981 528i in Kastanienrot-Metallic, 16" Alpina, 1958 Isetta 300 in Federweiss/Pastellblau
original thread here
http://forums.bimmerforums.com/forum....php?t=1328893
additional by DnA Diesel:
Since you have a 540i/6 like I do, and I just happened to replace my heater core yesterday and took pics, I'll point out a few differences between the DIY an our IHKA - Mk III-F systems...still Behr, but reconfigured core and feed lines.
Radio out first...well, okay, this is pretty much like all E34s...except note the 6-shooter trigger in the bottom of the picture... That said, it's the "manual-automatic" climate control system that we'll be noting the differences on...
http://i144.photobucket.com/albums/r...DnA540i-01.jpg
Yeah, sort of the same as well...
http://i144.photobucket.com/albums/r...DnA540i-02.jpg
When you're removing the forward portion of the console, you'll have to disconnect the ASC switch, the cigarette lighter and the cig ltr's bulb.
http://i144.photobucket.com/albums/r...DnA540i-03.jpg
On this HVAC unit, you have to disconnect the manual airflow control cables for the defrost (red), front vents (blue) and the floor heating (green). Pinch the arms, then pul out. You'll have to rotate the control wire counter-clockwise by about 90* to unhook the eyelet from the control lever.
http://i144.photobucket.com/albums/r...DnA540i-04.jpg
There are also three electrical connectors on this panel: one not seen in the pics (it's on the left side, for rear defrost, recirc and a/c), and the two connectors on the right. Arrows indicate the direction to move the connectors to release them.
http://i144.photobucket.com/albums/r...DnA540i-05.jpg
With the console removed, and the Radio, OBC, HCAV front bezel out of the way, this is the cover to the airbox. There are a few more clips than those circled in red, here, but you get the idea. Be careful and cover your eyes (if your not already wearing safety classes) becaus some of these go flying pretty good. Also note the little lever you need to actuate to release the OBC (if you want to..don't need to as the wires for the OBC stay attached to the bezel...just move the beel out of the way into the open glove compartment).
http://i144.photobucket.com/albums/r...DnA540i-07.jpg
Here is the heater core. Note the different configuration of the supply piping from pre-92 units. There are no 2-piece feed lines, they are all single piece units that pass completely through the firewall. I didn't change these out, even though the heater core I got from Patrick at BMA Autoparts had a complete set of feed lines attached, so I detached the replacement pipes from the new core. Also note the little plastic arm connecting the driver floor heating divert valve to the passenger divert valve - the manual cable attaches only to the pass side valve, hence the need for the connector arm.
http://i144.photobucket.com/albums/r...DnA540i-08.jpg
These are the connector locations for the pass feed (right) and the drivers feed (front left) and return line (rear, left). The bolts are 8mm (and mine also had a Torx-20 in them).
http://i144.photobucket.com/albums/r...DnA540i-09.jpg
Here's the floor diverter connector arm again. Note/mark the position where the end of left arm fits into the right arm, and remove the clip (this is the same kind of clip as the ones used to keep the airbox closed.)
[Note: excuse the graphic text on the pic, it's not the defrost, it's the floor heat diverter.]
http://i144.photobucket.com/albums/r...DnA540i-10.jpg
Watch out that you don't lose the backing nuts for the pipe attachment collars, they are only sitting in their respective slots with gravity. They are square nuts and if you're new core doesn't come with them, you'll definitely need them to reassemble the core and pipes.
http://i144.photobucket.com/albums/r...DnA540i-11.jpg
Undo the bolts, then the pass feed collar rotates about 60* clockwise, then slides back along the feed pipe.
http://i144.photobucket.com/albums/r...DnA540i-12.jpg
This is a bit of a bugger to get to...I used a small 1/4" driver with the 8mm bit.
http://i144.photobucket.com/albums/r...DnA540i-13.jpg
Once you get the bolt out, you swing the collar upwards, towards the front of the car...you'll reverse this motion to lock the pipes into the new core, once installed.
http://i144.photobucket.com/albums/r...DnA540i-14.jpg
It looks bad, but so long as you are methodical, it's not too bad. I highly suggest taking pictures with a camera -- it makes a good reference to reverse things when you're done with the replacement.
http://i144.photobucket.com/albums/r...DnA540i-15.jpg
These connectors were attached to the outside of the airbox. Don't forget to hook them up again during reassembly.
http://i144.photobucket.com/albums/r...DnA540i-16.jpg
Since the tubes are aluminum, you can move them around a bit to get the old core out. The pass feed line needs to be moved up a fair bit to let the core clear out, be gentle and it should move nicely out of the way. The circles are where the O-rings (square-rings) are that you will replace. Also ensure you clean the end of the feed pipes well. There were some deposits, so I used a bit of CLR to clean the ends of the pipes, and ensured there was a nice clean surface to put the new o-rings onto.
http://i144.photobucket.com/albums/r...DnA540i-17.jpg
This is why our cars' heaters leak after a while.....
http://i144.photobucket.com/albums/r...DnA540i-18.jpg
Clean the interior of the airbox prior to installing the new core...I used bleach FantasticTM to ensure there was no coolant residue in the airbox plenum.
http://i144.photobucket.com/albums/r...DnA540i-19.jpg
Installation is the reverse of the removal...the one bugger is going to be securing the driver feed/main return line connectors into the left side of the core header, and getting that little aluminum collar down into position so you can insert and tighten the 8mm bolt. You have to really push the feed tubes into the core body, wiggle around a bit, because that collar has a tab on the far side that locks into the body of the core header, and the collar won't swing down into position to let the bolt be secured unless everything is well aligned.
Having done all this work, do not just cover everything up now...temporarily hook up the HVAC control head, run the car up to normal operating temperature, and ensure that there aren't any leaks. The two spots to look for in particular are where the pipes lead into the heater core.
http://i144.photobucket.com/albums/r...DnA540i-20.jpg
Good, no leaks...now to button everything up and grab a beer!
http://i144.photobucket.com/albums/r...DnA540i-21.jpg
snip all the hard part of putting this thing back together again...]
Cheers
Duey
p.s. don't forget the little plastic divider that separates the driver and passenger side of the core...I did after I put the cover on, and had to "practice" some more R&R to get it right. Nothing says "aw f....!" like finding an extra piece left over after you think you're all done!
Installation:
O rings:
Enjoy!
Trevor M
Cheers
Duey
JonathonK
E34/E28/E12 Discussion
04-30-2015 01:39 PM
