ZF 6 speed Flush
My Ride: 2007 E60 530d
Engine: M57
Hello.
Saw this video the other day
flushing the fluid from a Japanese (I guess) auto.
Seems pretty simple if:
Has anybody heard of this being done on a 6HP** auto via the cooling lines?
Is this what commercial shops do somehow?
Cheers
- The transmission can mechanically do this correctly - i.e renew the fluid this way
- You are very careful
- You are brave and/or thick skinned
Cheers
My Ride: 530i
Engine: N52
You could do that but the tranny coolant lines are at the bottom of the radiator on the driver's side .
So not really convenient to get to them w/o the car being lifted.
Also the lines use high pressure push-on fittings which make mating to any other lines a bit of a challenge
I plan to partially drain my unit this way next drain to get the dirty fluid out of those lines as well as out of the pan.
Engine: M57
Yes - I figured I would need to make an adapter for the lines - but I got a lathe so unless its got an odd geometry I should be OK.
My biggest fear is oil starvation - I would like to come up with a 1:1 input/output system with as little manual intervention as possible.
I wonder what pressure the pump runs at - couldn't find any specs on this.
My Ride: 530i
Engine: N52
That sounds like a little over the top for effort but doable I presume.
I can't imagine it would be a high pressure amount, but w/o that # it is a guess.
You can do a static drain that should clear a good amount out right at the cooler lines,
Engine: M57
Half the fun is making the tools.
Especially if they work well and get used again - by me or somebody else.
Static drain - do you mean when I empty the pan or just unplug the cooler and let it drain?
My Ride: 530i
Engine: N52
Static drain is releasing the lines at the cooler so the fluid can drain by gravity.
If you have time to machine parts that's great.
I sure don't.
I sure don't.
My Ride: 530i
Engine: N52
So here is the pressure info direct from ZF:
"The pump is making about 17 bar (246.56 psi) but the valve body reduces and regulates it to about 5 bar (72.519 psi) to the clutches"
Engine: M57
Thanks for digging that up. I wonder if 5 bar is carried through the rest of the system (cooling, torque converter).
My Ride: 530i
Engine: N52
He only states regulation to the clutches of 5 bars.
My guess is that for cooling the fluid is flowing at high pressure.
You can imagine how the torque converter will heat that fluid very quickly.
bestofthebest
03-28-2016 02:47 PM
